Onboard audio not working and audio drivers won't install
  1. Posts : 8
    win 7 ultimate 64Bits
    Hello Hopalong
    And thank you for your speedy reply.
    I followed the steps that you outlined and loaded the soundMax driver in win7 folder with the softwares that
    was preinstalled. After windows restarted I got this message
    "tHE SOUNDmAX AUDIO DRIVER DID NOT LOAD..Reinstall...". When that didn't work
    I uninstall the softwares and repeated the steps and installed the Driver before I installed the softwareS.
    I also loaded the latest update "ASUSUpdt-V71601_XPVistaWin7", and installed latest
    Intel_Chipset_V9111019_XPVistaWin7 that I downloaded from ASUSTeK Computer Inc. - Motherboards -
    ASUS Maximus II Formula.
    After all that the problem still remain, I am CLUELESS!
    Attached Thumbnails Attached Thumbnails Onboard audio not working and audio drivers won't install-0.jpg   Onboard audio not working and audio drivers won't install-1.jpg   Onboard audio not working and audio drivers won't install-2.jpg   Onboard audio not working and audio drivers won't install-3.jpg   Onboard audio not working and audio drivers won't install-4.jpg
  2. Posts : 5,941
       #12
    Hi there
    sometimes the problem isn't in the software but in the hardware.
    Have you got a setting either via a "jumper" lead or in the BIOS setup that you can DISABLE the audio from the video card.
    On the main board as well there is a switch (either jumpers or in the BIOS) that enables you to select HD audio or AC97.
    Ensure you've got the correct one.
    If your mobo has a built in video chip you could try using that and just remove the other video card. If you don't want to do that ensure the MOBO's video is disabled.
    Cheers
    jimbo
  3. Posts : 6,349
    This is what I would do and did before but is your decision to try or not. I would have suggested this yesterday but didn't have this picture of your Device Manager at that time.
    Delete all the yellow marked items under the "Sound, video and game controller."
    Right click each yellow item one by one then click delete.
    Then reinstall the SoundMax driver.
  4. Posts : 7
    Ultimate x64
       #14
    Well I have the same problem with my onboard sound card and asus mother board in Windows 7.I've installed every drive I could find and update bios and you name it so I bought a usb external sound card and still it doesn't work with windows 7 , and when i plug it in all it does is bingbong bingbong bingbong like when yoiu disconnect and re connect a usb device. I installed the cd that come swiththe device and still nothing.
  5. Posts : 8
       #15
    Hi guys
    With this sound problem still lingered and no audio... I am going "Bing Bong..Bing Bong..Bing Bong" myself
  6. Posts : 7
    Ultimate x64
       #16
    LOL me too
  7. Posts : 7
    Ultimate x64
       #17
    There is no yellow exclamation marks at all. The sound card is not showing up. Says no device installed.
  8. Posts : 6,349
       #18
    You can try the ASUS forums if you haven't already.
    Contact ASUS support. Maybe you will get some help.
    Good luck.
    Mike
  9. Posts : 6,349
       #19
    sassyonyx and id102
    In the start menu search box type find and fix
    You will see 8 items listed at the top.
    First try the Find and fix problems with devices. It is a repair wizard of sorts.
    If no help then try this one.
    Find and fix audio playback.
    If possilbe check to see if you have audio in speakers front and rear panel and/or earphone jacks on front or rear.
    I haven't forgot just looking for new ideas.
    Mike
  10. Posts : 6,349
       #20
    Also check to see if the audio is enabled in the Bios.
    The HDA controller in picture.
    It will be similar to my picture. It should show in your owners manual also.
    If this is disabled you will never have sound.
    Mike
