Solved +-30 second Audio alarm begins when I power on my W-7 Pro Laptop, why?
Mike Lynch
Pro User
11:58 PM
Clearwater Florida
It stops after about 30 seconds and everything runs normally.
I'm baffled as I do not know of anything that has changed, software or hardware wise.
Any guesses?
Mike
Microsoft Windows 7 Professional 64-bit 7601 ...Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz8.00 GBIntel(R) HD Graphics 4000
Two HP Desktops. One in the Laundry Room / Bed Room.
Hewlett-Packard 3396
8.00 GB
Hanns-G
1440 x 900 x 32 bits (4294967296 colors) @ 59 Hz
(1) ATA WDC WD40EZRX-00S SCSI Disk Device (2) HP Officejet Pro 86 USB Device (3) WD My Book 1230 USB Device
Whatever came with the CMT.
HP CMT Black.
Logitech K740.
Microsoft Optical Mouse 1000.
Spectrum 25Mbs.
WebRoot, Microsoft Security Essentials.
EDGE
HP Officejet Pro 8600 Plus.
WD MyBook 4TB.
Maybe if you let us in on the secret as to exact make and model of the laptop, somebody might know.
    7 X64i5 84002x8gb 3200mhz
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    pure power 11 400w cm
    Coolermaster
    cryorig m9i
    7x64g54008gb ddr4 2400
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
Thanks, I needed that "wake up" call!
ACER: Aspire
5734Z: Series
PAWF6: Model Number
N214: Unknown ?
Mike
8.00 GB
Hanns-G
HP CMT Black.
Logitech K740.
Spectrum 25Mbs.
EDGE
WD MyBook 4TB.
SIW2 -- is there a quick way to determine if the audio is generated from something aboard the motherboard or from any particular software-only glitch? And which device is making the noise - onboard mb squawker or from one or both speakers?
- - - Updated - - -
Mike Lynch -- have you found a way to determine if the audio is generated from something aboard the motherboard or from any particular software-only glitch? And which device is making the noise - onboard mb squawker or from one or both speakers?
Windows 7 Professional 64-bitDesktop i5; Acers i5 & i7desktop 16GB; 1 Acer 8GB & 1 Acer 16GB
Antec desktop; Acer Aspire laptops
1TB split into 2 equal partitions [OS and data] usable by RJS
AT&T DSL
FF, GChrome, msIE
Windows 7 Firewall, Emsisoft AM/AV, MSE [scan-only], SpywareBlaster, Ruiware/BillP combine
Here is the best input I can offer!
With the Laptop turned off an closed up:
I open up the Laptop, press the power on button and an Alarm begins to Screech!
+-30 seconds later, the Screeching stops and Windows-7 Pro is loading.
Once Windows-7 is finished loading, the Laptop functions normally.
That's it!
8.00 GB
Hanns-G
HP CMT Black.
Logitech K740.
Spectrum 25Mbs.
EDGE
WD MyBook 4TB.
