Audiophile EAX 4/5 sound card for XP and 7 Pro x64
SiRGadaBout
1:45 PM
UK
I'm currently in the process of returning a Creative XtremeGamer card because of all the problems I've had installing it, and the crackles and pops in use. In the process I've become aware that Creative's drivers are generally slated, and have been investigating alternative devices. I was interested in the Prelude and the Bravura by Auzentech, but it seems that, whilst they seem to be fine, on the whole, on XP, the drivers for Win 7 are atrocious (there's even a thread entitled "Class Action" on the Auzentech forums).
So, here's why I'm asking for help: I'm looking for a high-quality sound card with:
1) usable and reliable drivers for both 32-bit XP Pro SP3 & Win 7 Pro x64.
2) EAX 4 or 5 support (whether in hardware or software, doesn't matter).
3) TOSLINK output.
4) availability in the UK.
It can use either the PCI or PCI-Express (x1) port standard.
I doesn't need any bells and whistles like 5.1 or 7.1, or DTS/DD (though I'm sure any card of a certain price is generally guaranteed to have one or both of the former).
So, any relevant suggestions? Price isn't initially an issue, though given the option I'll choose cheaper over more expensive, so long as it has what I require.
Many thanks,
S.
PS: my PC's spec is available in my profile.
Windows 7 Professional x64 upgrade editionE6400 2.13GHz4GB 533MHz DDR2BFG 9800GTX+ OC using 258.96WHQL drivers
Dell XPS 700
E6400 2.13GHz
Dell-modified nForce 590 SLI
4GB 533MHz DDR2
Samsung SyncMaster 226BW
1kW
Dell Standard USB
Razer DeathAdder
10Mbps
SiRGadaBout, welcome to the forum.
Regardless of any and all other features you mentioned, if you want EAX 4/5 you have two choices and two choices only, Creative or any of the Auzentech cards that have a Creative chip on them. No other card has EAX 4/5 as Creative owns them and has only licensed it to Auzentech.
As far as problems installing your Xtreme gamer, was it a retail or retail OEM card, or did it come from Dell (based on your system specs)?
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Hi, and thanks for the welcome.
And… Bugger. I've really had it up to here with Creative's drivers, and I hear Auzentech's drivers are little better (being only modified Creative drivers anyway). Well, I'll modify my question slightly then, and add another:
Which of the cards offering EAX 4/5 have the most stable and unproblematic drivers for both of my OSes?
Which card would people recommend if I removed the requirement for EAX 4/5?
S.
Dell XPS 700
E6400 2.13GHz
4GB 533MHz DDR2
1kW
Dell Standard USB
Razer DeathAdder
10Mbps
