base to the max only, 5.1 system problem
Fking
9:08 AM
I've got a logitech 5.1 system which for some time now plays with base to the max no matter where the hardware controls of the base are.
I'm not even sure if it's a hardware or software problem, but it's really annoying, any idea how to at least narrow down the possible problem source?
Microsoft Windows 7 Enterprise 64-bit
Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
ASRock Z68 Extreme3 Gen3
12.00 GB Corsair and Samsung DIMM
(1) NVIDIA GeForce GTX 460 v2 (2) Intel(R) HD Graphics Fam
(1) NVIDIA High Definition Audio (2) NVIDIA High Definitio
Dell 23" + Acer 21"
1x128GB Samsung 830 SSD
2x500gb Western Digital Black on Raid 1
Elite cooler master
1 on the back, 1 on the front next to the HDDs
What's the interface from the PC to the audio system?
(The only sound device that you list if from the graphics card, which would usually be digital only: HDMI, maybe DisplayPort.)
Does your sound controller have bass settings?
homegrown
Windows 7 Pro X64 SP1
Intel Core I7-3930k
Asus P9X79 Pro
16 GB Gskill DDR3-2133
eVGA GTX680
Creative X-Fi Titanium
As PA246Q
1920 X 1200
Corsair Force GT, 120 GB
WDC 1.5TB Caviar Black
PCP&C Silencer 750 Crossfire
Silverstone FT02
Noctua NH-D14
cheap Logitech USB
Microsoft Intellimouse Explorer (old optical) USB
6Mb cable
Pioneer BDR-205
Samsung SH-203B
Monsoon 5.1 speakers
there are 3 or 4 3.5mm jacks that go from the motherboard to the main body of the system which is also the subwoofer
i have some settings and sound effects for it under control panel> sound if i play with the equalizer there it seems to affect it.
Seems that it's just the hardware controll of the base that's connected to the subwoofer itself doesn't work anymore :(
Dell 23" + Acer 21"
Elite cooler master
If I understand things correctly, you're using the Realtek onboard audio, with analog connections to your sound system.
The bass control of your sound system isn't working.
Sounds like a repair/replacement of the sound system is in order. Or, live with it.
homegrown
Intel Core I7-3930k
Asus P9X79 Pro
eVGA GTX680
As PA246Q
1920 X 1200
Silverstone FT02
Noctua NH-D14
cheap Logitech USB
6Mb cable
Pioneer BDR-205
Samsung SH-203B
