Battery Problem
Reckoner
8:48 PM
Since I installed Windows 7 RC1 on my PC, I started having a problem related with my Sony Vaio VGN-FE41S battery. When I insert it, my computer displays an error saying that the battery is incompatible and the computer will hibernate because of that.
Any solution?
Hi Reckoner and welcome to Se7en Forums :party:
This sounds like a power management driver issue. What does your laptop actually do when the battery is installed (apart from displaying this message)?
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
Thanks for the welcome message. :)
Well, after I put the battery, Windows 7 recognize it but that message appears and nothing more. After the message, my PC just goes to hibernate mode.
Did you install W7 with the battery inserted, and was the battery charged when you did so?
Gigabyte IF233
Avast! 8.0.1497
IE 11
OK. Try reinstalling W7 with the battery inserted (and charged).
Gigabyte IF233
Avast! 8.0.1497
IE 11
Forget! I just solved the problem reinstalling the power management drivers. Thanks, anyway! ;)
I'm pleased that you have managed to solve your problem. I note that it was, as I suspected, an issue with the power management drivers.
Gigabyte IF233
Avast! 8.0.1497
IE 11
How to reinstall Power Management Drivers?
Reckoner,
I have the same problem, where did you did you find the correct driver?
I tried to reinstall the drivers from Sony without success.
Thanks,
Vítor
