BELKIN Wireless G USB adapter Problem- again
tasman26
4:29 AM
Hi all members.
I read alot topics on this forum to try solve my problem. I found in here 2 topics about Belkin Wireless G USB adapter , but still i have a problem
I describe whats the problem .
I try to instal on my Windows 7 x64 b.7000 drivers for belkin w g usb adapter f5d7050
I download drivers 4 belkin usb adapter f5d7050 ver.3(like I read about it) - before install i change in install file the compability for all users to windows xp , but it dont wanna install(I get a error)(the product only supports Win200/Winxp32/Vista32/Vista64) , then i switch compability for windows vista and instaler go on,
While installer is going it ask to connect adapter to usb ,what i do, but it seems dont find any anyway .
After all when instalation is finish i just get information that device dont work proply , and the light in adapter never go on
I try update drivers from menage device but still device is not working
I really dont know what else i can do
Mayby that will be some clue
i install Windows 7 on separetly partition "E" , so I have on c: vista , and on disc e:Win7 , but in windows 7 mode i cant see partition with Windows vista(I can see just in Disc menagment, that she still there),
. when i open windows vista i see all partitions.
did it make any sense?
I can make some screens if it help .
anyway my main problem is to instal belkin drivers 4 adapter to WORK fine,
Please help, and sory for my english but thats my second language
Regards tasman
When you did the update driver in the device manager did you browse to the belkin folder in your program folder.
I never had to install the driver with any compatibility. I just installed it then I just updated the driver in the device manager and going into the program files/belkin/model number and then it started to work.
HP Compaq Presario/SR5113WM
Windows 7 Ultimate x64/ Windows Vista Ultimate x64
AMD Athlon 64 X2 3600+ 1.9Ghz
Asus M2N68-LA
PNY Optima Memory DDR2 2GB 2x1 kit
PNY Nvidia 8400 GS 256MB
On board RealTek
Acer X163W LCD
1366x768
Western Digital 160 GB SATA 3G (3.0Gb/sec)
7200 rpm
Western Digital 160 GB IDE
Dynex 400w
Nothin Special
Standard 102 key with volume and sleep buttons
Wireless Logitech LX7
Comcrap 10mb cable
Insignia 2.1 speakers, wireless Xbox 360 controller w/plug n play charger, Belkin wireless G + mimo usb network adapter.
I have program files and Program files(x86) on same partition , in Program Files(x86) i go to belkin but its no Belkin.exe file at all just sec i make a screen
i cant find this file , just look i make A screen :
image.php
http://www.freeimagehosting.net/image.php?3408c65124.jpg
by the way its imposible to find proply instal files i think ,in old ver of windows i could find easly files after instal and here i havent got clue whats going on?
Cant see anywhere instalation files as well ??
http://www.freeimagehosting.net/image.php?10de3109de.jpg
image.php
as far as "seeing" your vista drive, make sure it has a drive letter assigned to it while you are in disk management... should also say healthy of course;)
CUSTOM
XP/win7 x86 build 7127
Athlon64 X2 DUAL 4200+ 2.21ghz
ASUS K8 PRO SLI
2GB Dual Chan DDR2 Corsair
Nvidia 6800GT
nvidia
19' LCD
1280x1024
WD 250, 2x500, 2x1TB IDE/USB
WD 250 SATA (system)
SEAGATE 120 Sata
coolermaster 450
SUPERFLOWER
1 HDD bay fan, 5x80mm Case Fans, AEROGATE II Fan/Temp
MS wireless
MS Wireless
fassssssssst
ok i sort drive, but still my network is not working :(
