Big Problem After Power Loss: Help Please
Robert11
Power User
7:48 AM
Hello,
New HP PC of a few weeks, running Windows7
Last night, inadvertently hit the AC power strip on/off button that the PC is plugged into.
Seems like the power strip being turned off, while PC was running, shouldn't be any big deal. We certainly have power outages also during the winter.
Turned it back on, turned the PC back on, and get that blue screen that has the
recovery option like F10=Setup, F11=System Recovery, etc.
Nothing works.
The keyboard does absolutely nothing.
Surprisingly, even the caps light won't come on, but perhaps the PC has to be actually functioning for this to work ?
Also tried, many time, to start the PC holding down F8 during the start.
Also tried pressing F8 on and off several times during the restart.
Nothing changes.
Still only that blue screen.
Pressing any of the option F keys during the restart process, or afterwards, does nothing.
Tried the keyboard in another USB slot with no change.
Pressing the power on/off button on the computer itself will not turn off the PC
once it has been pressed to turn it (back) on.
No restore, recovery, or W7 were shipped with the PC.
Any thoughts would be most appreciated.
Thanks,
Bob
Windows 7 64bit
Do a repair install.. You may need to do this three times to ensure that everything is resolved... Hope this helps...
LENOVO K450 @3.0GHZ
64-bit Windows 8.1 Pro
LENOVO
12.00 GB
Intel(R) HD Graphics
Intel HD integtrated
HP 25' ISP Monitor
100mb down/10mb up
From OP: How, Please ?
Thanks for help.
New at this.
Exactly how do I do a "repair install" please ?
Again, nothing happens from keyboard, or on turn-ons.
What do I do, please to do this ?
Much thanks for help; sure do appreciate it.
Bob
Windows 7 64bit
Any chance you have or can borrow a non USB keyboard to try? It may pay to clear the CMOS as well to reset your BIOS to default.
Home Built
Windows 7 Ultimate RTM
AMD Phenom II x4 945
Asus M4A785 TD V Evo
6GB PC1600 DDR3
1GB XFX Radeon HD 5770
Onboard
2x Daewoo 19" TFT
1440 x 900
WD 120GB SATA
Hitachi 250GB SATA
Enermax 450w thing
None...well half a case
Thermalright Ultra-120 eXtreme 120mm Heat Sink
GPU Cooler: Thermaltake V2
