biig driver problem :( need help plzz
aek2007
3:39 PM
I have no idea whats going on with windows 7 ?? I just installed it , its famous for its drivers but there are no drivers installed what so ever ??!
it wouldn't let me boot from the CD it said '' couldn't boot code 5'' ldk so l installed it from my windows XP and everything went fine and when it loaded there were no sound , graphic card driver installed the higher reslotion l can get is 1024*768 ?? and there is no sound driver installed l have a 256 of memory in my graphic card but it sais 32 or something l think its on safe mode ? cuz there's no zooming in or out or any of those cool graphic features its really simple and biiig from the low relolution and l its in english and l wanted it to be in french?? just so u know it worked perfectly with my friend ?! l have a bit of an old computer :
cpu : 2.8
ram : 1.25 gb
graphic card : ATI readon 9200 (memory 256)
yea i know its a bit old but l really need help maybe its cuz l didn't boot from outside windows ldk any one know how l can fix it plzz .. :confused:
cpu : 2.8
ram : 1.25 gb
where would you like to start? what one problem needs to be fixed first?
ken
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
it wont recognise anyyything on my computer ??! l want to fix my graphic and sound card first cuz l want all those featured to be visual on my pc as in the sooming in and out and high resolution cuz now l cant change it from 1024 ahh and the sound card and thnx alooot for the help mate :)
What version of Windows 7 are you using?
Gateway, Toshiba Laptop, and Home Brew
Windows 7 x64 HP, Windows 7 HP, Windows 7 Ult
Intel I3, Cerelon, Pentium 4 @ 3Ghz
Intel, Intel, Asus
8G, 3G, 3G
On-board Intel, On-board nVidia, nVIDIA card
on-board, on-board, SoundBlaster
Hannspree HF237, Toshiba, SyncMaster 931B
default (all)
1T internal, 320G internal, 160G internal, 1T networked
300w, unk, 650w
black, black, grey
air (all)
standard wired (all)
6M down, 768K up
Home LAN through Linksys hub to 4 port and wireless switch/router. Networked HP 2600n. Wife's computer running Windows 7, and spare laptop running Ubuntu "Karmic Kola" (9.10).
So that one problem was what?
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
Go to your hardware manufacturer site and download the drivers. It's not that hard.
MasterB/Custom
Windows 7 Professional x64
QuadCore AMD Phenom II X4 Black Edition 955 3.2 GHz
Asus M4A785TD-V Evo
8 GB Crucial DDR3
SAPPHIRE Radeon HD 4890 1GB HDMI New Edition
VIA VT1708S HD Audio 7.1 onboard/ ATI HDMI video card
Acer H233H 23'' LCD HDMI
1x 500GB and 1x 1TB 7200RPM 32MB Cache WD Caviar Black
CORSAIR CMPSU-620HX 620W
COOLER MASTER Storm Scout SGC-2000
2x 140mm and 1x 120mm case fans, Stock CPU fan
Logitech MX 3200
Logitech MX 3200
15 Mbps
My first build!
