Please run one of these free, independent online malware scans to ensure that your current protection hasn't been compromised: Malware (read the details at the link)
Then, if the above tests pass (this refers to the HDD and Memory tests), I'd try these free stress tests:
FurMark download site: FurMark: VGA Stress Test, Graphics Card and GPU Stability Test, Burn-in Test, OpenGL Benchmark and GPU Temperature | oZone3D.Net
FurMark Setup:
- If you have more than one GPU, select Multi-GPU during setup
- In the Run mode box, select "Stability Test" and "Log GPU Temperature"
Click "Go" to start the test
- Run the test until the GPU temperature maxes out - or until you start having problems (whichever comes first).
- Click "Quit" to exitPrime95 download site: Free Software - GIMPS
Prime95 Setup:
- extract the contents of the zip file to a location of your choice
- double click on the executable file
- select "Just stress testing"
- select the "Blend" test. If you've already run MemTest overnight please run the "Small FFTs" test instead. (run all 3 if you find a problem and note how long it takes to error out with each)
- "Number of torture test threads to run" should equal the number of CPU's times 2 (if you're using hyperthreading).
The easiest way to figure this out is to go to Task Manager...Performance tab - and see the number of boxes under CPU Usage History
Then run the test for 6 to 24 hours - or until you get errors (whichever comes first).
This won't necessarily crash the system - but check the output in the test window for errors.
The Test selection box and the stress.txt file describes what components that the program stresses.
More details on the use of this test: Torture test your CPU with Prime95Two other video stress tests (may be more stressful than FurMark):
Video Memory stress Test - МИРNVIDIA / Утилиты / VMT
Artifact Locator - МИРNVIDIA / Утилиты / Artifact Locator
Sorry, but I don't read the language that this website is made in.
[font=lucida console]
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Debug session time: Tue Nov 30 11:23:47.940 2010 (UTC - 5:00)
System Uptime: 1 days 0:22:12.126
Probably caused by : memory_corruption ( nt!MiIdentifyPfn+26f )
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x3B
PROCESS_NAME: svchost.exe
Bugcheck code 0000003B
Arguments 00000000`c0000005 fffff800`02b85b1f fffff880`056dccb0 00000000`00000000
[/font]
