BSOD: driver power state failure problem
kumineko
3:35 PM
Hi my laptop has this driver power state failure blue screen of death when its about to shutdown but recently its has been doing it when i am just using the laptop. I really dont know what is causing the crashes and Microsoft errors can be so explicit really, so i was hoping for some help with this issue. Before i just go and return the laptop to frys and get something else with the warranty.
here is the system info:
Is Windows 7 . . .
- x86 (32-bit) or x64 ? 64bit
- the original installed OS on the system? windows 7
- an OEM or full retail version? oem
- What is the age of system (hardware)? 2 months
- What is the age of OS installation (have you re-installed the OS?) once a system restore to resolve the same problem and it resolved it for a while but the problem came back again.
HP Pavilion dv7-4180us laptop
Windows 7 home premium 64bit
Intel Core i5-460M Processor 2.53GHz with Turbo Boost Techno
4GB DDR3
ATI Mobility Radeon HD 5650 s
Beats Audio and HP Triple Bass Reflex Subwoofer
BSOD caused by an HP device, Go into safe mode if possible and uninstall any Hewlett Packard devices you have and update the drivers and software
BugCheck 1000009F, {4, 258, fffffa8004187680, fffff80000b9c510}
Unable to load image \SystemRoot\system32\DRIVERS\hpdskflt.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for hpdskflt.sys
*** ERROR: Module load completed but symbols could not be loaded for hpdskflt.sys
Probably caused by : hpdskflt.sys ( hpdskflt+2b9b )
Intel Core 2 Quad Q8200 OC'd 3.08GHz
Asus Rampage formula LGA775
8GB DDR2 900Mhz
MSI GT730 2GB GDDR5 (Kepler)
Supreme FX2
Samsung LS22F350 LED
1080P
Kingston SSDNow UV400 120GB, 500GB Hitachi, 2TB Samsung, 500GB Seagate FreeAgent, 640GB Samsung, 160GB Toshiba (Arch)
AeroCool 500W Bronze
Cooler Master V6 + 3X fans
Prolink keyboard
Logitech M705
1MiB/s
Chrome Beta
hi, well the laptop is hp so there is no way i can go in there and start removing devices considering almost all software is hp . but i guess once i do a backup of what i have in the laptop i can do a fresh reinstall of the windows 7 without using the oem version that came with it but just windows 7 alone and get the drivers for my video, sound and network separately.
4GB DDR3
The BSOD may be caused by a startup HP program such as Solution Center and other software preinstalled on the laptop, the best thing you can do is to update these or remove unwanted HP software
Remove HP 3D DriveGuard if it is installed
8GB DDR2 900Mhz
Supreme FX2
1080P
Prolink keyboard
Logitech M705
1MiB/s
Chrome Beta
