BSOD Kernel-power41(63)- need solution
Niirti
7:03 AM
Help! This is driving me crazy. I've had 11 BSOD in the last month, ever since I built my new computer and installed W7 32bit.
Every single one ideitifies its source as: Kernel-power 41(63)
It first happened when I used Windows Live to download my emails, then it occured a couple of times while downloading a patch update for World of Warcraft. It's also happened at my loggin screen before I've even entered my password.
My hardware info is as follows:
Motherboard: MSi P55-CD53
CPU: Intel core i5-750 processor
PSU: Hiper 800w
RAM: Corsair xms3 4gb (2x2gb) DDR3
Graphics: Nvidia GeForce 8800 GTS
My partner thinks it's a psu problem but I haven't come across any forums reporting a problem with Hiper PSUs. I've read other forums who say it could be my anti-virus AVG.
The error report I last got was:
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 28/11/2009 15:50:35
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: Helen-PC
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2009-11-28T15:50:35.139218700Z" />
<EventRecordID>11297</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>Helen-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">209</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x4</Data>
<Data Name="BugcheckParameter3">0x1</Data>
<Data Name="BugcheckParameter4">0x91208ace</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
Please help!! This last crash was in the middle of a game so it's starting to get very annoying now. Any assistance/advice you can give me would be greatly appreciated. :)
Windows 7 32bit
MSi P55-CD53
Optiquest Q19wb
Samsung SP2540C ATA device
Hiper 800w
PSU: Hiper 800w
Log Name: System
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: Helen-PC
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
Hi niirti and welcome
can you go into c:\windows\minidump, zip the dmp file and opload it to us for debugging?
if you need help instructions are here http://www.sevenforums.com/crash-lockup-debug-how/34900-1-novice-how-ask-help-bsod-problem.html
also to upload the zipped dmp file use the attachment icon in the reply form see pic
let us know if you need any help
Kenn J++
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
dmp file
Most recent dmp file zipped and attached as requested.
Please let me know if you need anything else.
Windows 7 32bit
MSi P55-CD53
Optiquest Q19wb
Hiper 800w
Just happened twice in quick succession
It's still happening and I wondered if you have any ideas on a soloution. Here's a copy of the last crash:
Log Name: System
Date: 17/12/2009 18:57:20
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: Helen-PC
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2009-12-17T18:57:20.259224200Z" />
<EventRecordID>15701</EventRecordID>
<Correlation />
</System>
<EventData>
<Data Name="BugcheckCode">25</Data>
<Data Name="BugcheckParameter1">0x20</Data>
<Data Name="BugcheckParameter2">0x8796e720</Data>
<Data Name="BugcheckParameter3">0x8796ec70</Data>
<Data Name="BugcheckParameter4">0x8aa000a</Data>
</EventData>
</Event>
Please it's getting v frustrating. Thought updating the bios had sorted it but obviously not. :(
Windows 7 32bit
MSi P55-CD53
Optiquest Q19wb
Hiper 800w
I had exactly the same problem with the same error code.I always suspected my drivers but apparently they weren't.Have you checked the right timing of your ram, because my problem was that my rams were working at default settings which was 1333 mhz, I chose XMP(Extreme Memory Profile) in Bios and they are working at 1600 mhz now since then I haven't got a Bsod.May be worth trying....
If your rams are overclocked at factory settings and if you are using them at default settings they may not be taking the required voltage and that may be causing Bsods as it was in my problem....
And my board is P55 as well, so you must have the same setting in Bios, I recommend giving it a try and check cpu temperature with realtemp or coretemp just in case...
Windows 7 64 bit
Intel Core i7 2.80
Gigabyte Ga P55 UD5
Team 2x2 1600mhz cl7 ddr3
Zotac Gtx 275
Samsung P2250
Western Digital Caviar Black
Thermaltake ToughPower 750 watt
Aerocool Sclone
I also experienced the same kernel power event id 41 freezing. The solution for me too was to adjust memory speed, but in my case unfortunately I had to lower the memory speed from 1333 MHz to 1066 MHz.
AMD Phenon II 905e X4
ASRock M3A770DE
4GB A-DATA DDR3 1333MHz
ATI Radeon 5850 HD
Sound Blaster X-Fi Xtreme Audio PCI Express
Acer V233H, Acer X233H, Acer X233H
5760x1080 (Eyefinity)
Samsung HD501LJ - 500GB (internal)
Western Digital My Book 1TB - 1000GB (external)
Lacie Petit Disk 320 GB USB 2.0 - 320GB (external)
Nexus 550W
Antec 300
Microsoft Comfort Curve 2000
Microsoft IntelliMouse Explorer 3.0
10M/1M
For starters:
Please start by running these hardware diagnostics:
Memory Diagnostics (read the details at the link)
HD Diagnostic (read the details at the link)
Also, please run one of these free, independent online malware scans to ensure that your current protection hasn't been compromised: Malware (read the details at the link)
Then:
Upload Dump Files
Please go to C:\Windows\Minidump and zip up the contents of the folder. Then upload/attach the .zip file with your next post.
{Left click on the first minidump file.
Hold down the "Shift" key and left click on the last minidump file.
Right click on the blue highlighted area and select "Send to"
Select "Compressed (zipped) folder" and note where the folder is saved.
Upload that .zip file with your next post.
If you have issues with "Access Denied" errors, try copying the files to your desktop and zipping them up from there. If it still won't let you zip them up, post back for further advice.
If you don't have anything in that folder, please check in C:\Windows for a file named MEMORY.DMP. If you find it, zip it up and upload it to a free file hosting service - then post the link to it.
Then, follow the directions here to set your system for Minidumps (much smaller than the MEMORY.DMP file): Set MiniDump
Home built (x64), Lenovo x61s Tablet, Samsung Netbook
Win7 x64 + x86
Intel i7 920, other Intel chips, and the Atom in the netbook
Asus P6T Deluxe
12 gB; 4 gB Lenovo; 1 gB Samsung netbook
ATI 4870
Yes, I have one of these
32" Sharp Aquos TV
800x600 - I have vision issues
4 - 150 gB Velociraptors in RAID 5
Promise controller
1000 watt (can't recall the brand)
Antec 300
Big honking cooler that was rated highly at Toms Hardware
Microsoft Natural
Logitech Trackman
Cable
GeekSquad UPS
CyberPower UPS
DLink DNS-323 NAS (2 tB)
Netgear wireless router as an access point
Netgear wired router FSV-318
Home network consists of
4 desktop computers (2 Vista, 2 Win7)
1 netbook (Win7)
4 laptop computers (XP, 2-Vista, Win7)
Wii and XBox 360
