BSOD Problem.Any effective solution?Please help me.
blaze331
10:52 AM
Hello friends.. any solution for my problem? I face with BSOD problem.My dell laptop crash repeteadly even I,ve tried so many solution to overcome this BSOD problem n even it is still a new laptop.
-when I check the caused of the problem using bluescreen view software,its show that it is caused by tcpip.sys.Please help me.I've not install any software to be the cause of this problem,it is just happen this week without any reason.Please help me..
I also attach the crash file from minidump folder..Thanx a lot..=)
Window 7 Home Premium 64-bit
Welcome to SF!
The most straightforward reading of your dmp looks like your network adapter drivers are causing the issue. I suggest uninstalling them completely in Device Manager, and installing a fresh copy. If you can find an updated version on the computer manufacturer's site, use it.
I also suggest removing Kaspersky completely in Programs and Features, and then running its removal tool: http://support.kaspersky.com/downloads/utils/kavremover10.zip
Then download and install Microsoft Security Essentials.
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Jonathan\Desktop\050210-18345-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 7600.16539.amd64fre.win7_gdr.100226-1909
Machine Name:
Kernel base = 0xfffff800`03203000 PsLoadedModuleList = 0xfffff800`03440e50
Debug session time: Sun May  2 02:04:23.648 2010 (GMT-4)
System Uptime: 0 days 4:55:31.365
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 1E, {ffffffffc0000005, fffff8000327c275, 0, ffffffffffffffff}
Unable to load image \SystemRoot\system32\DRIVERS\kl1.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for kl1.sys
*** ERROR: Module load completed but symbols could not be loaded for kl1.sys
Probably caused by : tdx.sys ( tdx!DbgTdxReferenceTransportAddress+2f )
Followup: MachineOwner
1: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8000327c275, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: ffffffffffffffff, Parameter 1 of the exception
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
FAULTING_IP:
nt!KeAcquireSpinLockRaiseToDpc+55
fffff800`0327c275 f0480fba2900    lock bts qword ptr [rcx],0
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  ffffffffffffffff
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800034ab0e0
 ffffffffffffffff
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0x1E
PROCESS_NAME:  System
CURRENT_IRQL:  2
EXCEPTION_RECORD:  fffff880060a7808 -- (.exr 0xfffff880060a7808)
ExceptionAddress: fffff8000327c275 (nt!KeAcquireSpinLockRaiseToDpc+0x0000000000000055)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
TRAP_FRAME:  fffff880060a78b0 -- (.trap 0xfffff880060a78b0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000002 rbx=0000000000000000 rcx=0073006900640284
rdx=fffff88003b71810 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8000327c275 rsp=fffff880060a7a40 rbp=0073006900640284
 r8=00000000000005b7  r9=0000000000000000 r10=fffffa8001dc7d80
r11=fffffa80068dcdb0 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei pl nz na pe nc
nt!KeAcquireSpinLockRaiseToDpc+0x55:
fffff800`0327c275 f0480fba2900    lock bts qword ptr [rcx],0 ds:00730069`00640284=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff800032ad929 to fffff80003273600
STACK_TEXT:
fffff880`060a7038 fffff800`032ad929 : 00000000`0000001e ffffffff`c0000005 fffff800`0327c275 00000000`00000000 : nt!KeBugCheckEx
fffff880`060a7040 fffff800`03272c42 : fffff880`060a7808 00000000`00000002 fffff880`060a78b0 fffff880`03b71800 : nt!KiDispatchException+0x1b9
fffff880`060a76d0 fffff800`0327154a : fffff800`03402800 fffff800`033a887c fffffa80`03d2c000 00000000`00000000 : nt!KiExceptionDispatch+0xc2
fffff880`060a78b0 fffff800`0327c275 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiGeneralProtectionFault+0x10a
fffff880`060a7a40 fffff880`03b75bff : fffff880`03b71810 00000000`00000000 00000000`000005b7 fffffa80`01dc7d80 : nt!KeAcquireSpinLockRaiseToDpc+0x55
fffff880`060a7a90 fffff880`03b80ee0 : fffffa80`01dc7d80 fffffa80`068dce00 fffffa80`01dc7d88 00730069`00640064 : tdx!DbgTdxReferenceTransportAddress+0x2f
fffff880`060a7ad0 fffff880`03b737cf : fffff800`00b96080 fffffa80`01eed350 fffffa80`05e46ce0 fffffa80`0615d9a0 : tdx!TdxConnectConnection+0x80
fffff880`060a7be0 fffff880`0471d344 : fffffa80`068dcd60 fffffa80`068dcd60 fffffa80`072afa80 fffff880`009e7180 : tdx! ?? ::FNODOBFM::`string'+0x8ec
fffff880`060a7c10 fffffa80`068dcd60 : fffffa80`068dcd60 fffffa80`072afa80 fffff880`009e7180 00000000`00001740 : kl1+0x49344
fffff880`060a7c18 fffffa80`068dcd60 : fffffa80`072afa80 fffff880`009e7180 00000000`00001740 00000000`00000188 : 0xfffffa80`068dcd60
fffff880`060a7c20 fffffa80`072afa80 : fffff880`009e7180 00000000`00001740 00000000`00000188 fffffa80`068dcddc : 0xfffffa80`068dcd60
fffff880`060a7c28 fffff880`009e7180 : 00000000`00001740 00000000`00000188 fffffa80`068dcddc fffff800`00b96080 : 0xfffffa80`072afa80
fffff880`060a7c30 00000000`00001740 : 00000000`00000188 fffffa80`068dcddc fffff800`00b96080 00000000`00000000 : 0xfffff880`009e7180
fffff880`060a7c38 00000000`00000188 : fffffa80`068dcddc fffff800`00b96080 00000000`00000000 fffff880`04730f60 : 0x1740
fffff880`060a7c40 fffffa80`068dcddc : fffff800`00b96080 00000000`00000000 fffff880`04730f60 fffffa80`036a5770 : 0x188
fffff880`060a7c48 fffff800`00b96080 : 00000000`00000000 fffff880`04730f60 fffffa80`036a5770 fffff880`0471df09 : 0xfffffa80`068dcddc
fffff880`060a7c50 00000000`00000000 : fffff880`04730f60 fffffa80`036a5770 fffff880`0471df09 fffffa80`068dcd60 : 0xfffff800`00b96080
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff880`03b75bff 4d8d8c2428030000 lea     r9,[r12+328h]
SYMBOL_STACK_INDEX:  5
SYMBOL_NAME:  tdx!DbgTdxReferenceTransportAddress+2f
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: tdx
IMAGE_NAME:  tdx.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc16b
FAILURE_BUCKET_ID:  X64_0x1E_tdx!DbgTdxReferenceTransportAddress+2f
Windows 7 Professional x64
Intel i7 2600K OC'd @ 4620 MHz
Asus P8Z68-V Pro
16GB GSkill Sniper 2133 Mhz (4x4GB)
EVGA GeForce GTX 480 SuperClocked+
2x Acer S273HLbmii 27"
2 x 1920x1080
64GB Crucial M4 SSD
Storage: Hitachi 1TB 5400RPM, Samsung 1.5TB 5400RPM
Corsair HW Series 750w (modular)
Cooler Master HAF 932 Advanced Blue Edition
CM Hyper 212+ CPU cooler, 3x 230mm + 1x 140mm case fans
Logitech MK320 (wireless)
30 Mb/s : 2 Mb/s
