BSOd, sound card static, and Slow browsing speed.
OmegaDead
2:12 AM
I constantly have my windows explorer freeze up to where i can't even pull up task manager. The sound card stutters and sometimes sounds like static. At least a couple times a week this eventually ends in blue screen of death. I bought the computer within the past 6 months. I have enclosed a zip file with the needed reports.
Dell Xps 8300
Windows 7 64bit
Intel Core i5 2400 cpu @3.14ghz
I have done no reinstall or changed the operating system since i purchased it pre-built from dell.
Windows 7 64bit
Dell Xps 8300
Windows 7 64bit
Dell Xps 8300
Windows 7 64bit
Blamed on US224x64.sys. I can find no reference to this file so it is either very unusal or may be malware. Dated 2007 so if you know what it is you should update it, if you dont I wold download malwarebytes and run it. If you are unsure you can remove it or rename it to *.bak so it wont load.
US224x64.sys    8/29/2007 3:52:34 PM        fffff880`00dbf000    fffff880`00df5200    0x00036200    0x46d5ce82
US224Wdmx64.sys    8/29/2007 3:52:58 PM        fffff880`063a0000    fffff880`063af880    0x0000f880    0x46d5ce9a
How To Find Drivers:
- search Google for the name of the driver
- compare the Google results with what's installed on your system to figure out which device/program it belongs to
- visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
- if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program.
- - The most common drivers are listed on this page: Driver Reference Driver Reference
- - Driver manufacturer links are on this page: Drivers and Downloads
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
ok i tried to remove that prior to doing the system reports. The device is no longer supported by the manufacturer, so there is no updated driver. It is from an external soundcard. i thought i uninstalled the drivers but I am still having the problem. but you are saying the drivers are still on my computer? It's been unplugged from the usb port.
Windows 7 64bit
Dell Xps 8300
Windows 7 64bit
They are still there and loading. They are blamed for the crash
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
