Built-in network adapter problems and stuck on "Enabling..."
AJMac
11:36 PM
I've had my Dell Inspiron for a few months now, but from the time I first booted it up, I've been riddled with problems.
My latest one concerns the wireless connection. After using the built in wireless card for a few minutes, it will suddenly cut out and show as alternating between having full connection and only one bar every second or so. Other devices at the same range have no problem when this occurs and it doesn't happen while wired. A very temporary work around (as in a few minutes) is to diagnose the adapter within control panel.
So far, I've gotten around this by using an external wireless adapter. However, that too has its fair share of problems. Its status will suddenly show that I have no internet access (again, other devices at the same distance work perfectly fine). Diagnosing it does nothing and disabling and reenabling of through the Network Adapters window in the control panel shows a window saying "Enabling..." with the loading icon as the cursor and seems to freeze on that.
Any help for either (or both!) of these problems is much appreciated.
Cheers
Windows 7 64bit
Hi AJMac and welcome to Seven Forums. Have you tried uninstalling the driver for your wireless adapter and then reinstalling it? If you go to the Dell website you should be able to download the driver for your wireless adapter and give that a shot. Support for Home Users | Dell US
Customized build from CyberPower
Windows 7 Home Premium 64bit SP 1
Intel i5 2500k
Asus P8P67 Deluxe
8 gigabytes Corsair PC3-12800 DDR3
EVGA GeForce GTX 460 superclocked
ViewSonic 23" LCD
1980 x 1080
120 Gb Samsung 840 Pro SSD
120 Gb Kingston Hyper X SSD
1 Tb WD Caviar Black HDD
Coolermaster 1000 watt modular
Coolermaster HAF X full tower
Coolermaster Hyper 212 plus
Logitech USB
Microsoft 3 button
download 1.5 Mb/sec upload 300Kb/sec
