Solved changed sound card - now no system sound??
Burgurne
Danish Viking
3:15 PM
Denmark
Greetings.
Used onboard sound until today where I remounted my Auzentech X-Fi Forte. I have uninstalled the realtek sounddrivers and deactivated the onboard sound in BIOS.
Everything is playing with the default analog speakers (5.1 setup) through the Forte, except systemsound (logon sound, program error, USB connected/disconnected aso). When open controlpanel -> Sound -> change system sounds I can NOT test the selection. They play allright, I think, but not via the Forte soundcard, so no sound i put out. When selecting Windows soundlevels and move the sliders up and down some bizar thing happen. When placing the cursor over the "speaker-slider" and move it, I hear a DING. But when placing the cursor over the systemsound and move it, no sound is generated.
How do I change that? :o
Windows 7 Ultimate x64 retailCore i5 3570K @ 4,4Ghz16Gbyte Corsair C9 1866mhzMSI Lightning GTX 770
homebrewed
MSI Z77A GD65
Auzentech
BenQ 24"
1920x1200
Samsung 840 EVO SSD, Samsung SSD 830 256Gbyte, Seagate 3Tbyte HDD, WD 4 Tbyte HDD.
Zahlmann 850HP
Corsair Carbide 500R
G15 logitech
Logitech Laser MX1000
Bitdefender
Did you get the latest drivers from the Auzentech site and use those?
Windows 7 Ultimate 64
MSI P67A-GD80 b3
XFX Radeon 7870 2GB DDR5
Sound Blaster Z Series Card
1680 X 1050 p
(1) 1 tb WD Black
(2) 1 tb WD green/sata II
(2) 3 tb Seagate Barracuda
(1) 120 gb OCZ Vertex SS
(1) Drobo 5N w/5 Seagate 3tb
CoolerMaster Storm Styker
Basic 120mbps down
Chrome and IE 10
Netgear Nighthawk router
Asus USB 3 & sata 6 PCIe card
Drobo 5N advanced NAS
Yep. Tried the official "new" driver from Auzentech and also the "PAX" drivers.
Same issues with both drivers
homebrewed
MSI Z77A GD65
Auzentech
BenQ 24"
1920x1200
Zahlmann 850HP
G15 logitech
Bitdefender
If you have an optional PCI Express lane you may want to try that and see if problem continues. Have you contacted support for Auzentach for any idea's?
MSI P67A-GD80 b3
1680 X 1050 p
(1) 1 tb WD Black
Basic 120mbps down
Chrome and IE 10
I can't contact auzentech as they have closed down (look at www.auzentech.com), but I might have found a solution myself.
If I put the soundcard in one of the 16-lanes (for graphics cards!!), then it works, but my graphic card then only have 8 lanes to use (will I ever see the difference?). Putting the soundcard back to a single-lane slot, then the problem is back. Maybe a defect mobo then?
homebrewed
MSI Z77A GD65
Auzentech
BenQ 24"
1920x1200
Zahlmann 850HP
G15 logitech
Bitdefender
Try very carefully taking a clear paint brush and compressed air and clean the offending lane, even repeated insertions and removals may get it to self clean an align.
MSI P67A-GD80 b3
1680 X 1050 p
(1) 1 tb WD Black
Basic 120mbps down
Chrome and IE 10
Bingo! That did it :)
Cleaning the socket with compressed air (or maybe inserting the card this time?) make it works again.
Thanks for the help.
homebrewed
MSI Z77A GD65
Auzentech
BenQ 24"
1920x1200
Zahlmann 850HP
G15 logitech
Bitdefender
Always look for the simple physical connections first then move from there ! Congrats on a awesome sound card....blast some high res. files for me !
MSI P67A-GD80 b3
1680 X 1050 p
(1) 1 tb WD Black
Basic 120mbps down
Chrome and IE 10
