Solved (Code 24) - Power Controll Error - Help
Steven511
9:03 PM
Hey all, I have this problem and get this
"This device is not present, is not working properly, or does not have all its drivers installed. (Code 24)"
I tryed going to drivers and it says under "Current Status" saysStatus: Stoped and I try clicking Start but gives me yet another Error - "The system encountered the following error while attempting to start the service - The system cannot find the file specified"
any help welcome, my power supply is - Antec true power quattro 1200 watt
Thanks in advance all.
Home Made
Windows 7 Home Premium (x64) (build 7600)
3.20 gigahertz AMD Phenom II X6 1090T
Gigabyte Technology Co., Ltd. GA-890GPA-UD3H
6GB RAM
Nvidia Gtx 580
(TV)Samgung 32"
1.81 TB
Antec Nine Hundred Two
Logitech G19
Razor Naga
50 MB
Take a look in Device Manager and see if your device is listed. Do you know what device the message is referring to?
Dell and Custom
System 1: 8GB System 2: 8GB
System1: Viewsonic HDMI 24"
10 MBPS
Thanks for the reply and yes it shows up in device manager but has the triangle with the ! in it and next to the Power Controll
Edit - Oh and its with in the device manager as in "None-Plug and Play Drivers"
Home Made
6GB RAM
Nvidia Gtx 580
(TV)Samgung 32"
1.81 TB
Logitech G19
Razor Naga
50 MB
Can you provide a screen capture of this?
(oh, and it's "non-plug and play", but not a big deal at all)
Dell and Custom
10 MBPS
Here
Home Made
6GB RAM
Nvidia Gtx 580
(TV)Samgung 32"
1.81 TB
Logitech G19
Razor Naga
50 MB
Are you running cyberlink powerdvd?
Dell and Custom
10 MBPS
CyberLink Blu-Ray
Home Made
6GB RAM
Nvidia Gtx 580
(TV)Samgung 32"
1.81 TB
Logitech G19
Razor Naga
50 MB
I think if you uninstall this program, the problem may resolve itself. If it does, there are alternatives to play blu ray.
Dell and Custom
10 MBPS
ye I have reinstalled windows and it has seem to have gone
Home Made
6GB RAM
Nvidia Gtx 580
(TV)Samgung 32"
1.81 TB
Logitech G19
Razor Naga
50 MB
