Common Installation Problems and Their Solutions
Jonathan_King
SF Team
4:47 PM
Rednecksville
Many people are posting in this category with the same problems, so I have put together a guide listing common scenarios and their solutions. One thing to note is that while an In-Place Upgrade may seem easier, there is a greater chance that something may go wrong. Most of the users on this forum agree that doing a clean install is the safer option.
One tip does not fall into any category. If you created the disc yourself (e.g. you downloaded the files, and created a bootable disc from them), try burning at the slowest speed possible.
Make sure the power cable is plugged in, as well.
Problem: Setup is stuck at X%
What to try:
Disconnect all unnecessary hardware from the system. This includes hard drives, video cards, USB devices, and expansion cards. Remove all but one stick of RAM.
Use the VGA output on your card if possible.
These problems can also be caused by bad RAM. Run a memory diagnostic overnight, using Memest86 or something similar.
If nothing above works, you may have bad installation media. What condition is the disc in? Verify your copy of Windows came from a reputable source. Try burning a new DVD, using the slowest speed possible.
Problem: Error message “Setup was unable to create a new system partition or locate an existing system partition.”​
What to try:
Make sure that the partition is primary, active, and formatted with NTFS.
Instructions for marking a partition as active using Diskpart:
Open an elevated command prompt:
Method 1: From Windows
Click on Start and type “command prompt”
Right-click on the application and select “Run as administrator”
Choose “Yes” when asked to confirm
Method 2: From a Windows install/repair disc
Boot into the install/repair disc and wait for it to load
Choose “Repair my computer”
Select “Command Prompt”
Type diskpart and press enter.
Enter list disk and note the number of the disk you want to install on.
Enter select disk n n is the number of the disk.
Enter list partition and note the number of the partition you want to install on.
Enter select partition n n is the number of the partition.
Enter active
You can now close the command prompt and re-attempt installation.
Problem: Setup does not recognize hard drive during installation
What to try:
If possible, boot into the install disc and run the installation from there, as opposed to running setup.exe from withing Windows.
Make sure that the HDD is detected in BIOS.
Try changing the SATA setting in the BIOS to AHCI, or IDE if AHCI is already set.
As a last resort, because this will erase your data, try this tutorial.
Problem: Setup forces computer to reboot, and never finishes installation
What to try:
Sometimes setup fails when recovery partitions are still present. For example, Acer and HP both put a special recovery partition on their systems, that cannot be easily deleted.
To delete the partition using Diskpart:
Open a copy of Diskpart following the instructions given earlier.
Enter list disk
Enter select disk n
Enter delete partition override
Now try reinstalling Windows.
Problem: Missing CD/DVD Drivers...
What to try:
Change the BIOS setting from IDE to AHCI or RAID (if your planning to use RAID).
AHCI is for SATA components, HD, DVD etc.
If AHCI or RAID is set in the BIOS it will install the drivers.
Windows 7 is trying to find IDE drivers for a SATA DVD.
Change the BIOS and try the install again.
Some users have also reported that they solved this problem by deleting the recovery partitions that came with the computer.
If you still have problems with the DVD drive try installing with a USB memory key: http://www.sevenforums.com/tutorials/2432-usb-windows-7-installation-key-drive-create.html
Thanks to Dave76 for the last solution, in this post.
If nothing is working, try clearing your CMOS. There is usually an option in the BIOS to reset to defaults, or something along those lines.
If none of the above suggestions work for you, please create a new thread in the Installation section. DO NOT reply to this post with your question.
Windows 7 Professional x64
Intel i7 2600K OC'd @ 4620 MHz
Asus P8Z68-V Pro
16GB GSkill Sniper 2133 Mhz (4x4GB)
EVGA GeForce GTX 480 SuperClocked+
2x Acer S273HLbmii 27"
2 x 1920x1080
64GB Crucial M4 SSD
Storage: Hitachi 1TB 5400RPM, Samsung 1.5TB 5400RPM
Corsair HW Series 750w (modular)
Cooler Master HAF 932 Advanced Blue Edition
CM Hyper 212+ CPU cooler, 3x 230mm + 1x 140mm case fans
Logitech MK320 (wireless)
30 Mb/s : 2 Mb/s
Some may need SATA driver or RAID driver for their motherboard and/or RAID controller ready on DVD, USB or HDD attached to non-RAID hard drive if setup does not recognize hard drive while installing.
Helpful thread. +rep
self built
7600.20510 x86
P4 550 3.4 GHz HT running at 3.5 GHz
MSI PM8M3-V (MS-7211 v1.x) Micro-ATX mainboard
OCZ 2 GB(2x1GB) DDR400mHz running @ 414 mHz
HIS Radeon HD 3850 IceQ 3 Turbo HDMI Dual DL-DVI AGP
MOTU Traveler firewire studio interface 192 kHz 24 bit
22" widescreen Acer X223W LCD, 17" Compaq P75 CRT
1680x1050 and 1280x1024
SATA I x2 WD, 400 GB and 120 GB, SATA 2 WD Caviar Black 1 TB
350W generic
Cybertronpc, it glows blue
stock cpu fan, Ice-Q 3 gpu and system, many case fans
Logitch Classical Keyboard 200
Logitech Mediaplay cordless
1792/448 kbits/sec
SATA II PCI fake RAID adapter, 1 GB Readyboost, original ATI Remote Wonder (even works with WMC perfectly), Logitech Rumblepad 2 game controller x2
Should I add that to my post, or leave it be?
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
It's fine. :D
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
Thanks!
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
a
b
c
d
e
f
g
h
i
j
k
l
m
n
Excellent idea,
We see a lot of similar issues coming up repeatedly, a sticky thread for these will help the users and those that are trying to help.
Good direction and well laid out +rep
76~2.0
Intel Core i5-3570K 4.6GHz
Gigabyte GA-Z77X UD3H, f18
Onboard VIA VT2021
22" LCD Dell
Samsung 840Pro 128GB SSD,
Corsair HX650W
Cooler Master Storm Scout
Logitech Wave
CM Sentinel
Dismal
Opera Next
Desktop: eSATA ports,
External WD USB 500GB
Homebrew PC - "Alpha_Dawg"
Windows 7 Ultimate 64 bit Steve Ballmer Signature Edition
Intel Core 2 Quad - Q9550 - 2.83GHz stock - OC'd to 3.6GHz
Gigabyte EP45-UD3P
4GB DDR2 800MHz (PC6400) OCZ Reaper
Nvidia GE Force 8800 GTS
Asus Xonar DX
Samsung SyncMaster 2333HD
WD Caviar Black 750GB - 7200RPM - 32MB cache
WD Caviar Green 1.5TB - 5400RPM - 64MB cache
WD Caviar Green 2.0TB - 5400RPM - 64MB cache
PC Power & Cooling Silencer 750
Gigabyte 3D Aurora
Case is Air - 5ea. 120mm fans (mix of Arctic and Xigmatec)
MS Natural Wireless KB
MS Wireless Mouse
50 mbps down/5 mbps up
AVerMedia - AVerTVHD G2 Dual Tuner Card
Clearing the cmos fixed the "set up is stuck at X percent" issue on 4 completely different machines for me using different media everytime. Just trying a different installation CD has also worked for me. Just thought I would pass this info along.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
GSkill Phoenix Pro 120GB SSD
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Thanks, chev65. That is a great addition.
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
Installation completing...errm i will crash instead.
Hello people,
Im having lots of problems with windows 7, whenever I try and install (both 32 or 64 bit edition) it would either hang at 36% (very rarely) or it would go through the whole process, restart to "installation complete" process and then 30secs into that it hangs (almost everytime). There is no BSOD or error messages, just a freeze. I know you've mentioned stripping the desktop to the bare minimum but just incase my problem might be a little more precise that you folks might have come across?
Many thanks for your time and support.
Self Build
windows 7, windows XP
AMD Athalon 64 X2 Dual Core 3.0GHz
Asus
nVidia GeForce 8800 GT
Creative x-fi Audigy
Samsung SyncMaster T200
1680 x 1050 32bit
Samsung 160GB
700w
Hello people,
How long are you waiting, Try leaving it overnight.
Just try the solutions one by one, and if none of them work, post back.
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
Hi Jonathan,
During the installation you can physically see the dots moving and actually move the mouse cursor around.... when it freezes none of these activities indicate movement ie.. mouse cursor fails to move, and dots stay stationary. I have waited a couple of hours before to see if its loading a large file or something but still no indication from the hard-drive..just a strong blue light which stays on, which could be another sign.
I've given up, it will take considerable time just to see if windows 7 would work, Just installed windows XP, without halting without freezing, without stripping it. And it works like a charm.. feels like another gimmick from Microsoft. Anyway thanks for your help and support. Wish you all the best with windows 7,
Tadaaaa, Fixed it! my problems consisted of memory RAM, Sound Card and Mass Storage Controller driver, and other stuff related to the motherboard drivers. Huge thanks to the guys (dolls?) who mentioned about keeping the system to the bare minimum.
**Recommended Reading if your installation keeps Freezing and after installation...**
Requirements:
1) Make sure you have a DAY OFF.. this **** will take time.
2) Watch the news on regular intervals...there are serious world problems out there other than your PC not working (feel good factor).
3) You must...a big must get the correct/updated drivers for your wireless or network adapters..need the internet for downloads... oh and if you got your motherboard drivers.. that would also help.
First off
As mentioned above in all the posts.. strip any extra hardware that isn’t essential such as memory RAM, if you have onboard sound and a pci sound card...take the pci sound card out (this was what caused some of my problems). Take out extra usb connections etc etc. Your installation should go through just fine (If not then prob your ram sticks need replacing). Installation Problem Solved...
Next problem...
Windows kept freezing randomly.... Run windows in safe mode.. and begin searching & updating all your drivers through safe mode (this is why it’s important to have the internet access). Go into device manager and pluck away at the problematic hardware’s, (the ones with explanation marks) some of the problems with mine were motherboard drivers. Download good registry management software... like 50% of the issues were bad registries that win7 had made. After I had cleaned up on that my machine was running smooth. Get a good anti-virus and internet security program...just so that you’re not camping on bad viruses. Do all the updates through windows update... hopefully you begin to notice your machine running smooth.
Recap:
1) Be prepared to spend alot of time on this.
2) Take out additional non-essential hardware, as discussed above by the grand master posts before me (cheers guys..(dolls?).
3) Get the latest updates for all drivers and motherboard drivers.
4) slowly put additional hardware back in one by one.
5) Download: 1) Registry management software (I used Registry Booster) and clean up your registries. 2) Anti-Virus and Internet Security Software.
6) Keep checking for updates and actively do this as this (it’s a new OS by Microsoft lol).
Hope this helps anyone who thought they were knee deep in it. Again guys thanks for all the help before.. but the **** made sense in the end...
"...At least with windows your guaranteed to face a problem, a problem which you actively engage to solve and learn something technical and then help others with this problem; instead of looking at a student with a cheap t-shirt telling you what you need to buy to sync with your MAC...”
Self Build
Asus
1680 x 1050 32bit
Samsung 160GB
700w
hello! i have an lg r510. i start installing windows 7 and when it restart it stuck. i cant have acces to bios or boot menu. any ideas? plz help i need mylaptop cause i have exams in few days! thanks
LG r510
windows7
Exactly what happens the very next second after you tun on your machine?
Asus P8Z68-V Pro
2 x 1920x1080
64GB Crucial M4 SSD
30 Mb/s : 2 Mb/s
Make sure Plug and Play OS is set to yes in the bios.
self built
7600.20510 x86
350W generic
1792/448 kbits/sec
Make sure you create your partion and format after you build your raid array, I figured that one out.
My build
xp pro Win 7
Intel Core i7-920 Bloomfield 2.66GHz 4 x 256KB L2 Cache 8MB
GIGABYTE GA-EX58-UD5 LGA 1366 Intel X58 ATX Intel
Crucial Ballistix 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
XFX HD-577A-ZNFC Radeon HD 5770 (Juniper XT) 1GB 128-bit GDD
On Board Audio Channels 8 Channels
Dell 2407WFP
1900x1200
2 Seagate Barracuda ES.2 ST31000340NS 1TB 7200 RPM 32MB Cache SATA 3.0Gb Raid 0, WD 350 GB, Maxtor 160 GB
CORSAIR CMPSU-1000HX 1000W ATX12V 2.2 / EPS12V 2.91 SLI Read
Lian Lia Aluminum
Noctua NH-U12P SE2 120mm SSO CPU Cooler, Several case fans
Logitech Track ball
Comcast Hi Speed
Dual boot XP Pro Win 7
thank you guys for the help and ur concern! i bought a new hdd and i install vista finally because i dont have time for experiments with windows 7.. Its exams time :S maybe i will install windows 7 after the exams and i will need ur help then:D
LG r510
windows7
Hello, i was going to start a thread, but i decided to ask my question here if you dont mind. Feel free to delete it if you wish and i will post a thread...thanks!
Ok, i built a "whitebox" for a friend at work and they wanted to windows 7 64bit. So, i built the machine and have been trying to figure out how to get it to recognize the HD for the past 4 hours... mainly thanks to Samsung for making inpossible to find drivers on their website for the Spinpoint F1 HD102UJ 1TB hard drive that i bought... Anyway, suggestions? I gone through all the suggestions about checking the BIOS for RAID settings, but there is only 1 drive in this machine.
Furthermore, after trying to find the drivers online for about 2 hours...i ended up reformatting the drive from the utility disk that samsung had on their website....
The ruff specs are:
Gigabyte GA-MA78LM-S2H (AM3/DDR2)
OCZ StealthXStream OCZ700SXS 700W
AMD Athalon II x2 250 Regor
4g OCZ Reaper DDR2-800
LG DVD+/-RW (SATAII)
Samsung Spinpoint F1 HD102UJ 1TB
Thanks for the help!!
me
windows7 64-bit
amd
gigabyte
ocz
integrated
integrated
acer
SAMSUNG Spinpoint F1 HD102UJ 1TB
ocz
cooler master
air
All working well, BUT
When I do Windows update
I get - Error code 80070103
AVerMedia A317 Mini-Card Hybrid Analog/ATSC
does not install & gives me Error
Please Help
Alienware m17
Windows 7 Ultimate
Core 2 Extreme CPU Q9300 @ 2.53GHz
2x3870 Ati
2x500 GB Samsung 7200rpm
