Connecting Front Panel Audio to Sound Card
Andrewawright
2:07 PM
N. Yorkshire
I have a front audio panel and a CMI 8738-6ch sound card.
The front audio does not work and has a wire coming directly from the back of it with this plug on the end of it...
There are 4 wires going into this plug.
On the sound card I have a 4 pin connector which, by trying with the computer turned off, I know fits this plug.
Despite them fitting together, this being the only wire coming from the front audio panel and plug being on the sound card we all know that naivety often makes 2+2 = 5 and so I was hoping some could offer guidance before I plug something in wrong.
Thanks in advance.
Windows 7 Ultimate x64Intel i3Patriot Signature 1333mhz 2 x 2GBPowerColour RADEON HD5450 1GB DDR3
Intel i3
Gigabyte H55-UD2H
C-Media 8738
Currently using LG 37'' TV
Western Digital Caviar Blue 250GB PATA Primary
Western Digital Scorpio Blue 250GB SATA
Western Digital Caviar Green 1.5TB SATA
Stock Compaq Presario
PC Line Wireless
PC Line Wireless
I am not intimately familiar with that card, though normally, yes, that would be the correct connection.
Windows 7 x64Intel i7 2600kG.skill Ripjaw 16gigs @ 1866Nvidia gtx580 (evga)
Insane hobo technologies. ;-)
Windows 7 x64
Intel i7 2600k
Asrock z68 extreme 4 gen 3
Integrated HD audio + hdmi
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
1 western digital 1tb (eSATA)
1 Seagate 1tb (eSATA)
Zalmann
Microsoft wireless 3000 (v2)
Thanks for the quick response.
Under normal circumstances, is there any adverse effects to connecting the wrong way round or will it simply not work?
Intel i3
Gigabyte H55-UD2H
C-Media 8738
PC Line Wireless
PC Line Wireless
It should simply not work if connected wrong.
It may be that the pins on the connector are wired differently than the pins on the card. In which case, you may have to rewire the connector.
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
I'll give it a go tomorrow then and let you know how it goes. Thanks for your help.
Intel i3
Gigabyte H55-UD2H
C-Media 8738
PC Line Wireless
PC Line Wireless
