Context Menu - Right Click vs Shift Right Click
How to Expand the Windows 7 Context Menu for More Options
This will show you how to expand the Windows 7 context menu to see more available options to select from for a file, folder, desktop, Windows Explorer root window, Windows Explorer window, and the Send To menu.
Here's How:
  • Default Context Menu (Left screenshots below)
    • Right click on item.
  • Expanded Context Menu (Right screenshots below)
    • Press Shift and hold while right clicking on item.
    • Select the item, and press Shift + Menu button on keyboard (if available)
      NOTE: Sometimes you may also need to press the FN (function) key along with the Menu button.
1. Desktop Context Menu
2. File Context Menu
3. Folder Context Menu
4. Windows Explorer Root Window Context Menu
5. Windows Explorer Window Context Menu
6. File or Folder "Send To" Context Menu
7. Taskbar Icon Context Menu
NOTE: This addition by Mr GRiM.
Right Click:
Shift + Right Click or Shift + Menu button
Hey Shawn
I wonder if there's a way to make this behaviour the default one...instead of having to hold the Shift key and right click, just right click for the expanded context menu. I'll have to look thru the contextmenuhandlers an see if this can be accomplished.
Personal Build
Vista Ult 64bit - Windows 7 Ult 7264 64bit
Intel Core 2 Duo E6750
Asus Commando
4 G's Crucial Ballistix Tracer
BFG Nvidia 8800 GTS 340
Creative Sound Blaster X-FI Platinum FATAL1TY
2-22" HP W2207 LCD
3 x 500G WD Caviar SATA II
Enermax Noise Taker II 600W
NZXT Lexa Classic (dual doored & windowed)
Zalman 9700 CPU cooler - 4 x 120mm, 1 x 90mm fans
Logitech MX 5500
Logitech MX Revolution
Blazing...
Here are some more extras when using Shift + Right Click
Without Shift
With Shift
Home Brew
eVGA 750i FTW
2x2Gigs Patriot PC2-6400 LL
Inno3D GeForce GTX260 216 SP
SATA 150GB
SATA II 250GB
USB IDE 750GB Ext.
Liquid Cooling System
Logitech G15 Gaming Keyboard
Logitech G9 Gaming Mouse
Thank you Mr GRiM.
Added. ;)
Your welcome Shawn.
Home Brew
eVGA 750i FTW
SATA 150GB
SATA II 250GB
USB IDE 750GB Ext.
Send To - Reveal All Hidden User Folders
Right click on a file and hover over Send To.You will see a limited number of available locations to Send To. Repeat while holding down the shift key. Now you will see all available locations revealed.​
That's it.
Limneos
ENIAC
Windows 7 RC 7100 32bit/64bit
Intel Core2Duo E4500 2.20 GHz
ASUS P5LD2-X/1333
2x1GB Kinsgston DDR2 800MHz
Nvidia 8500GT
Onboard High Definition Audio Device
Sony Bravia 42"
LINKW 2222
Standard Intel
Some cheap one
Microsoft Intellimouse something
24MBps ADSL
This is a good one! Nice find Limneos. ;)
Windows 7 Build 7048 x64
Athlon 64 X2 Dual Core 4600+
EMX-AMD750G-PRO
4 x 1GB Kingston 400MHz 6-6-6-18 (800MHz)
ATI Radeon 3650
22" AOC 2216Vw
Arctic Cooling Freezer 64 Pro PWM
Generic Enhanced Natural Keyboard
Logitech VX Nano
Edifier M1550
Limneos,
Thank you for the addition. It has been added. :)
Your welcome, Shawn!
Since it's embedded here, I would like to add that if you type in start -> search: shell:sendto , it opens the SendTo folder without having to navigate to the whole path
(C:\Users\youruser name\AppData\Roaming\Microsoft\Windows\SendTo) , where you can drag and drop or paste new shortcuts for the SendTo menu.
Cheers
ENIAC
ASUS P5LD2-X/1333
Nvidia 8500GT
Sony Bravia 42"
LINKW 2222
Standard Intel
Some cheap one
24MBps ADSL
Yes, find in the registry the one you always want to show, in the right hand pane, delete the string value "Extended"
Averatec 6130HS-20
Windows 7 Professional 32-bit (6.1, Build 7600)
Intel(R) Pentium(R) 4 3.00 GHz HT
2.0 GB
ATI Mobility Radeon 9600 64MB
Realtek AC'97 Audio
1280 x 800
Seagate 96023A 60GB 7200RPM -
Seagate FreeAgentDesktop 250GB
20 Inch Box Fan
Targus PAWM10 Wireless Optical Laptop Mouse
Hey! I'm not very familiar with the registry (at least not enough to browse it and find stuff), but I wouldn't mind having the right-click on open windows in my taskbar to be default 'shifted'. Where can I find the taskbar 'Extended' in the registry? Thanks.
Vista and Seven
I'm sorry if this has been answered in another thread but I haven't seen a solution anywhere.
1) Is there a way to have the right-click context menu pop up where you right click instead of always above the program?
2) If not, is there a way to permanently enable the shift + right click behavior for the Win7 taskbar without having to hold shift down? I find the location of the new context menus to be annoying. I like the old way where the menu would pop up where I right click and not always in the same spot above the taskbar.
Self built
Win7 HP x64
Intel i7 920 @ 4GHz
Asus P6T Delux
6GB OCZ DDR3
HD4870 1GB
On board
24" BenQ
2x WD640
1x WD 1TB
Corsair 850w
Cosmos
H50 liquid cooling
Thanks Greg S. This was the only thing that was driving me nuts with Windows 7. Now it is perfect! I am a programmer and work a lot in the CMD window!
Happy New Year to you and everyone else! Be Safe!!
XP and Win 7
Hey dude, as I mentioned earlier, I'm not familiar enough with the registry to find my own solution. Can you help me? Where is the string value "Extended" located?
Happy 2010!
Vista and Seven
Happy 2010!
I'm not in Win 7 at the moment. I've searched for something that might make it easier for you. Have a look at this brief outline on ShellMenuView
Access and Customize Windows 7's Extended Context Menu - TechSpot
lol, I'm glad I searched that for you because I've used ShellMenuView before and never noticed the extended menu part of it.
Averatec 6130HS-20
2.0 GB
Realtek AC'97 Audio
1280 x 800
20 Inch Box Fan
江苏省
As usual, nice work Brink. :)
I knew about the command window trick, but I didn't realise that there were so many other hidden options.
n/a
ASUS M4A88T-M/USB3 (AM3)
NVIDIA GeForce GTX 660
Realtek?
Samsung S23B350
Cooler Master
Antec GX300 Tower
3x Antec TRICOOL 120mm Fans
Wired Optical
DSL
Pale Moon (64 bit)
2018-12-27 Upgraded HDDs
Thank you Lehnerus. :)
Keyboard Menu button
This also works using the "Menu button" on the keyboard (i.e. "Shift + Menu button" also brings up the extended context menu).
n/a
Realtek?
Samsung S23B350
Cooler Master
Antec GX300 Tower
Wired Optical
DSL
Pale Moon (64 bit)
Thank you Lehnerus. I forgot about that one. Added. :)
