device because it has reported problems. (Code 43) Help me pllz
eddy1991
5:39 PM
Well I tried again I did everything fine no it makes me Tsgiah Hzaot what to do to fix it?
windows 7 ultimate x32
Have you completely uninstalled and reinstalled the nvidia driver? If you dont know how to do that ill give instructions below
Start > Right click Computer > Manage
Click the little arrow next to "Display drivers"
Right click (in your case) NVIDIA GeForce 8800GT(Microsoft Corporation WDDM V1.1) > Properties
Then click on the tab "Driver"
Then Click "Uninstall"
Make sure you have a new driver ready for your card. also make sure the driver IS NOT a beta.
(all OS listed in x64) 7, 8, server 2003, 200...Intel Xeon E7-887064 Gig 32*2 DDR3 ECC 13332x GTX Titan
custom build
(all OS listed in x64) 7, 8, server 2003, 2008 R2
Intel Xeon E7-8870
Supermicro X8QB6-F
2x GTX Titan
x4 Asus 27''
2560 by 1440
WD 2TB 7,200 RPM SATA 6.0Gbps x4
Old server tower
Custom liquid cooled
Logitech trackball
Vipre
LoL name XeonPeaceMaker
Can you get me a link to download the driver please?
custom build
Intel Xeon E7-8870
Supermicro X8QB6-F
2x GTX Titan
x4 Asus 27''
2560 by 1440
Old server tower
Logitech trackball
Vipre
now only i need to insteal it ?
Once downloaded, just Right Click the Exe and click "Run as Administrator"
Follow the prompts, then once installed restart your machine. Let me know if this helps
custom build
Intel Xeon E7-8870
Supermicro X8QB6-F
2x GTX Titan
x4 Asus 27''
2560 by 1440
Old server tower
Logitech trackball
Vipre
ok i wiil do it now
again say me error 43 what need to do to fix it not work what u give me
well all i can think of is a bad graphics card/expansion slot. if you have a second expansion slot try moving the card over.
custom build
Intel Xeon E7-8870
Supermicro X8QB6-F
2x GTX Titan
x4 Asus 27''
2560 by 1440
Old server tower
Logitech trackball
Vipre
i dont hace a secont slot
The ticket was for a technician and the technician said that the card is fine with no seven
Do you see colored dots? The GeForce 8800 GT had soldering problems in its years
Windows 7 Home Premium 64-BITAMD A8 7200P8GB 1600mhzRadeon R5 (APU) + Radeon R5 M230 2GB Dual Gra...
ASUS X550ZE
AMD A8 7200P
N/A
8GB 1600mhz
Laptop Display
1920 x 1080 @60hz
Laptop Charger
ARMAGGEDON TEXTRON SCORPION 7
100 mbps DOWN / 50 mbps UP
Windows Defender
Yes I see but only on the screen of Huindos it costs
And now it gives me another error This device cannot start. (Code 10)
Click Troubleshoot to start the troubleshooter for this device.
Can be walked video card?
You could reball the graphics card again or if you can't, Just buy a new one :(
8800 GT should work without problems but it's the soldering problem that was made by NVIDIA is the one to blame.
ASUS X550ZE
AMD A8 7200P
N/A
8GB 1600mhz
Laptop Display
1920 x 1080 @60hz
Laptop Charger
Windows Defender
So what can you do cleaned Tcrtis screen I took it Sloat
But he catches him looking and says I need one file
You can not fix it?
now it say this
