Solved Driver Problem Help !!!
We will still be here :D
self build
amd phenom x4 9600
asus m2n32-sli deluxe
corsair twinxs 2x2gb
2x nvidia 1gb 8500gt
onboard
23" PB Viseo 233d
maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
oryxx tornado 750w
thermaltake xaser lll
artic freezer64 pro + 7 case fans
i have got an old laptop from my aunt
Its compaq presario v2000 cto
Config- intel celerom m 1.40ghz
Ram-1gb hdd-40gb intel 915gml graphics. I will use it as my mobile computer . Shall i use windows 7 or 8 . And which edition should i install
Self Made
Windows 7 Home Basic 32bit
Intel Pentium 4 with (HT) at 3.00 ghz
GIGABYTE 8I865GME-775-RH
1 GB DDR-1 AT 400mhz
Intel 865g
On Board
1024*768
1. WD80GB SATA
FOXIN FPS 360
3 MBPS
Hi Debajyoti, You will be able to run win7 on that laptop ,It will not be very smooth have you thought about using Vista on it If you do go the win7 route use the basic version :)
self build
amd phenom x4 9600
onboard
23" PB Viseo 233d
maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
oryxx tornado 750w
no never installed windows vista when i received the computer it was running windows 95 . Can you please tell me prices of some the 2.5 inch hdd in india . Shall i install win xp
Self Made
Intel 865g
On Board
1024*768
1. WD80GB SATA
FOXIN FPS 360
3 MBPS
self build
amd phenom x4 9600
onboard
23" PB Viseo 233d
maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
oryxx tornado 750w
