Dual Monitor (HDTV) Problem Radeon HD3450
lafargeotte
Power User
9:38 PM
France
I'm using a Radeon HD 3450 on Windows 7 with Catalyst 10.7
My monitor is connected through the VGA port, and it works fine.
I tried to connect my HDTV (LG 50PK350) as a second monitor through the HDMI port (on TV & HD3450). The TV (as 2nd monitor) is not detected and there is no signal on my TV.
The connection appears fine, as when I click 'Detect Displays' in CCC, the pc monitor screen flickers and tries to connect but eventually fails. (same using Windows 7 Display properties!).
I am using a brand new HDMI 1.4 cable.
Any ideas?
TIA
Win7 Ultimate x64, Windows 8 Enterprise x64AMD Phenom Quad Core 98654GBATI RADEON HD3450
Foxconn A6VMX
4GB
ATI RADEON HD3450
Realtek HD
Samsung SyncMaster P2250
Seagate ST380815AS (80GB) System Disk
Seagate ST31000528AS (1TB) - 2 Partitions (Programs & Storage)
Samsung HD1035SJ (1TB) - 3 Partitions (Downloads & BackUp)
450 watt
Generic
CPU & Case Fan
Logitech MK700
Logitech M705
20Gbs
Card have VGA, DVI and HDMI ports? If so the reason it won't work with the HDMI and VGA at the same time is both of those ports are running through the same RAMDAC, and only one of them can be used at a time.
If you can hook your monitor up to the DVI port using either a DVI cable, or if the monitor doesn't have a DVI port on it the card should have come with a DVI-VGA adapter. If it didn't you should be able to find one fairly cheaply, like this one,
Newegg.com - SAPPHIRE DVI to VGA adapter for Twin-View video cards Model DVI-2-VGA - Video Card Accessories
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
OK Thanks.
Explains why it works OK on TV without the VGA monitor being connected!
Foxconn A6VMX
4GB
ATI RADEON HD3450
Realtek HD
450 watt
Generic
CPU & Case Fan
Logitech MK700
Logitech M705
20Gbs
Doesn't the HDMI and DVI use TDMS?
from wikipedia,
As the use of DVI, HDMI, and other digital interface technology becomes increasingly mainstream, the
"DAC" portion of the RAMDAC will likely become obsolete. Digital interfaces use a TMDS module.
Windows 7 Ultimate 64bitIntel i7 3770K16GB DDR3 1333 Corsair XMS3XFX HD6950 2GB EyeFinity
HAL-9000
Intel i7 3770K
Asus Sabertooth Z77
Logitech G35 & Sennheiser PC135 & VIA HD
23" HP 2310e, 23" Samsung B2230, 21.5" Viewsonic
5760x1080
16TB of Storage
128GB & 256GB Crucial M4 SSD's, 2X 1TB WD Black, 3x 2TB WD, 3x 2TB Samsung F4, 1.5TB Seagate, WD 500GB,
Antec True Power New 650watt
Cooler Master HAF-932
Corsair H60 Hydro Cooler, 3x 230mm Fans, 2x120mm Fan
Logitech G15 and G13
Logitech G700 Gaming Mouse
50/10 Mbit
Speakers : Alesis M1 Active Mk2 Studio Monitors , APC RS 1200 UPS, HP 4500DN Color Laser, HP P1006 mono Laser, Kodak 8500 Dye-Sub, Epson 1280 inkjet, Epson Worforce 610 MFC
That's a pretty weak card. I used to have one and gave it up. I never got the HDMI port to work by itself, much less with another monitor connected. If you need to have HDMI and another connection, you might want to upgrade to a slightly better card.
Mellon Labs (custom build)
AMD FX 8350 Vishera @ 4200
ASUS M5A97 R2.0
Acer 24", Acer 22"
3840 x 1080
1 x WD 1TB SATA Blue
1 x WD 1TB SATA Green
Corsair TX-750
CoolerMaster HAF 912+
Logitech G710+
Logitech G500s
Corsair VOID USB headphones.
Hi Guys,
Thanks to stormy13's advice (the RAMDEC) I have solved the problem.
Now have HDMI & DVI connections (done away with the VGA).
Mellon Head the card satisfies my needs (not a gamer of any sort).
Thanks again this forum for another problem solved.
Foxconn A6VMX
4GB
ATI RADEON HD3450
Realtek HD
450 watt
Generic
CPU & Case Fan
Logitech MK700
Logitech M705
20Gbs
Glad you got it fixed. It's kind of nice to see someone happy with their hardware and not always going for bigger -> better -> more. I'm that way too. My video cards are a little old, but they do everything I need them to. :D
ASUS M5A97 R2.0
Acer 24", Acer 22"
3840 x 1080
Corsair TX-750
Logitech G710+
Logitech G500s
