Ethernet printer connection problem
Brian1000
8:34 PM
Hello,
I have a wired local Ethernet printer connected to a computer with windows 7 Ultimate x64. If the printer is turned off when I restart the computer the printer is no longer available (not in focus). To make the printer available I can do one of two things: restart the computer with the printer on or run the printer troubleshooter (I think it restarts the local adapter connection?). Is there a setting that will make the computer recognize the connection automatically when the printer is turned on? This computer is also connected to a wireless network through another Ethernet adapter.
Thanks for the help,
Brian
Dell XPS 9100
Welcome to SF,
Just need a little clarification regarding this. How is the printer wired and where to? If the printer has a network adapter it shd be connected to the Router or a Switch.
Make sure that the printer has a Static IP assigned. Looks like it might be causing an IP conflict to your network.
Lenovo Desktop/Samsung Laptop
Win7 & Win8 64bit
Intel i5
Charter-20 Mbps
FF, IE9 and Chrome
Welcome Brian1000 to the Windows 7 forums.
a couple of questions.
1. What is the make and model of the printer?
2. when you say it is connected to your computer, do you mean by usb and it is also via a network cable?
3. Is it setup as a static IP?
4. What software do you run when you say "run the printer troubleshooter?"
Rich
Toshiba Laptop Qosimo X870
Windows 7 Pro x64 SP1
Intel Core I7
Toshiba Qosmio
16 Gigs
NVIDIA GeForce GTX 670M
17.7" laptop
1600 x 900
256 Gig SanDisk SSD for C
256 Gig Intel SSD for D
50/25 FIOS
Vipre (all you can eat for 10 machines)
IE and FF
I have dos 6.22, wfwg 3.11, win98, 2000 and xp VHD's available for testing. MS's Virtual PC works great.
Thanks for the replys.
My computer has two ethernet adapter cards, one is wired to a wireless router (home network) and the other is wired to a Epson 3880 printer (this is the printer that I am having trouble with).
I set up a static IP for the printer, using the IP that a ipconfig /all comand gave me. The printer has a Auto IP assignment but that didn't work.
The troubleshooter is Windows 7 from the Device and Printers page.
Thanks again.
Dell XPS 9100
Brian, What you have is a really complicated arrangement for the printer. Why not connect the printer directly to the router via the ethernet connection? Or via USB if it is that close to be cabled to your computer.
I would recommend that you plug the printer into your router and let it pick up an IP directory from the DHCP server on your router. Otherwise set the printer up with either USB or printer cable. The two ethernet cards is a really unusual configuration.
Other than that, If it all works if you turn the printer on first and then your computer. That would be the recommended solution if you don't want to plug the printer into the router..
Rich
Intel Core I7
Toshiba Qosmio
16 Gigs
17.7" laptop
1600 x 900
50/25 FIOS
IE and FF
Totally agree.
Never seen this type of setup before, sorry.
We guarantee you that your issue will be resolved if you plug in directly the network cable from your printer to your router or a switch.
Please let us know.
Win7 & Win8 64bit
Intel i5
Charter-20 Mbps
FF, IE9 and Chrome
Thank-you.
Thanks for the help. Everything is fine now that I have abandoned the second Ethernet adapter and wired my printer directly to the wireless network router. Should have probably done this earlier but I thought I could get the other method to work. This is a good forum!
Brian
Dell XPS 9100
Totally agree with the solution. For info, normally, the only time you would need 2 network cards in a PC would be to use it as a "Bastion" server which would be acting as a firewall from one network to another.
win7
