Fujitsu Siemens Amilo Pro v3505 And WLAN problem
sajtmano
3:53 AM
Hi!
First of all: sorry for my poor English :o
I have a little problem with my laptop (Fujitsu Siemens Amilo Pro v3505 with Intel 3945ABG Wireless adapter):
The WLAN driver installed successfully, and it worked for 1 day - but after a reboot stopped working.
The WLAN LED is black, no activity, and the Network and Sharing Center didn't see any available network.
I tried to solve the problem on the Windows 7 control panel, but it said "try to switch ON the hardware".
I installed the Launch Manager (downloaded from the manufacturer's page, Vista version), and it's running, but when I push the WLAN button nothing happening.
Any idea?
Regards:
sajtmano
Windows 7 32 bit
Windows 7 32 bit
Same Problem
Hello,
I have the same problem. In addition when i press the WLAN button it does not start. Also I can not get back to win xp because i formated the hard drive using Windows 7 which is not compatible with win xp.
Any solution so far??????
Many Thanks
Same problem and solved
I had the same problem and I solved it by installing the launch manager (Vista version) from Fujitsu and turned on wlan with it.
Hope I could help
windows 7
windows 7
Many Thanks
Hello,
You really saved my life. Finally, it works.
Many Thanks:D
hi, i have the same problam... downloded the lanch manager and still the wirlass button dont respond... what sould i do?
windows 7
windows 7
I have had this issue for more than 2 years now and have used an external wireless USB stick. Just installed the Launch Manager for Vista (even if I'm running Win 7) and my wireless card is now working!
You guys rock!
Win7 32bit
Win7 32bit
Hi! how would you guys describe your experience with Win 7 on Fujitsu Siemens AmiloPro V3505? Is it better than XP?
windows 7 home 32bitintel centrino duo
fujitsu siemens amilo pro v3505
intel centrino duo
Thank you:)
win xp,vista,7,8. ubuntu12
Thank you valentin_30 May 2009
hi,
i had the same problem and i solved it by installing the launch manager (vista version) from fujitsu and turned on wlan with it.
Hope i could help
hi...sorry but where i can find the launch manager because in fujitsu web site is not available the download...can you help me?...thanks
Windows 7 Ultimate x32
Fujitsu Siemens
