Geforce GTX 670MX : Is there a way to set fan speed manually?
Question2
3:38 PM
The fan noise when running 3d applications is killing me. It's only at 50% usage and 48 degrees celsius according to GPU-Z but the noise is REALLY loud. It's a brand new laptop too, so there's nothing wrong wtih it, it's just the fan speed goes up too high...
win 7 64 biti7-2720QM4gbHD 5600 series
Lenovo ideapad y460p
win 7 64 bit
i7-2720QM
unknown
4gb
HD 5600 series
onboard sound
1366x768
Western digital
10 mbps down/0.8 up
Microsoft security essentials
Firefox/IE
Have you tried using a program like MSI Afterburner or SpeedFan? They are great programs to manually control fans, watch temperatures and even control voltages. Hope this helps, let us know if you have any more questions.
-JackALope
Windows 7 Ultimate x64Intel Core i7-2700K Sandy Bridge 3.5GHzCorsair Vengeance 16GB DDR3 1600MhzAsus GeForce GTX 670 2GB
Asus P8Z68-V Pro
Creative Sound Blaster X-Fi Xtreme 7.1
Samsung 24" LED Monitor
Corsair Force GT 240GB SSD
Western Digital 3TB HDD
Corsair AX860i Fully-Modular
Cooler Master HAF 922 Powder Coated White
Noctua NH-U12S
Razer BlackWidow Ultimate Stealth Edition
Razer Mamba
Verizon FiOS 20Mbps
Internet Explorer
Razer Tiamat 7.1 Surround Sound Headset
They wont allow me to set fan speeds for my laptop.
win 7 64 bit
i7-2720QM
unknown
4gb
HD 5600 series
onboard sound
1366x768
Western digital
10 mbps down/0.8 up
Firefox/IE
Skylake Special #666
Intel Core i7 6700K
Asus Sabertooth Z170 Mark 1
EVGA GTX 980 Ti SC x2
Realtek High Definition
AOC G2460PG
Logitech G910 Orion Spectrum
Doesn't work either. It says fan speed is 0% and thats obviously not true. Whats the limiting factor of controlling the fan speed?
win 7 64 bit
i7-2720QM
unknown
4gb
HD 5600 series
onboard sound
1366x768
Western digital
10 mbps down/0.8 up
Firefox/IE
Hi there ..... As already has been stated it may not be possible to adjust the fan speed .... One way that might be possible is by ... Checking your laptop make and model and research how to adjust the fan speed. There is no single, universal way to do this, so finding the exact model will help you do your research. Some brands have tips written in the user's manual.
windows 7 home 64bitINTEL-CORE I716GB
W530-3630QM1
INTEL-CORE I7
16GB
750GB
Well whats the limitation on adjusting fan speed? Why can some computers do it and others cant?
win 7 64 bit
i7-2720QM
unknown
4gb
HD 5600 series
onboard sound
1366x768
Western digital
10 mbps down/0.8 up
Firefox/IE
Hi there ..... Whats the Model number of your Laptop
W530-3630QM1
INTEL-CORE I7
16GB
750GB
OP, the why.... is hardware choices made by the manufacturer, it's just that simple.
Cutting corners on costs and consumers get less tweakable fare, sometimes.
I am surprised you have no fan adjusting options, in the bios and/or the Nvidia video applications. [Those are your two places to look, and if not in bios I would look for a BIOS update]
But, be glad the fan is running, laptops with all that hardware crammed into a small space, need circulation badly or it's broken in a matter of milliseconds.
Could check guru3d.com for a 3rd fan app, perhaps.
Windows 7 Ultimate Retail Box (64-bit install...AMD FX-8350 CPU v1.15 (or 1.0F) BIOS was requ...8G CAS-7 G-Skill DDR3 @1333 (2 fours) [mobo n...Radeon HD 7950 [3 gigs of GDDR5] MSI Twin Fro...
Self Built Custom
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
AMD FX-8350 CPU v1.15 (or 1.0F) BIOS was required!
MSI 890FXA-GD70
8G CAS-7 G-Skill DDR3 @1333 (2 fours) [mobo nonOC max rec'd]
Radeon HD 7950 [3 gigs of GDDR5] MSI Twin Frozr model
Realtek High Definition Audio (onboard mobo, ALC-889 chip)
2 WS LED Monitors: One LG One Viewsonic
1920 by 1080
SSD for OS: Samsung 840 Pro
SSD for VM and utilities: Adata SX900
7200 RPM SATA HDs for the rest: Hitachi and Seagate
Corsair TX850 - 850W max, in service since August 2010.
Thermaltake Armor A90
Thermaltake Spin Q CPU Cooler, in service since August 2010
Logitech G11
Logitech M310 Wireless
100 Megabit broadband supposedly upgraded from 50 (Cable)
Bitdefender Internet Security 2014 suite
Pale Moon 64-bit main, also IceDragon, Opera, and Maxthon.
CompTIA A+ certified (220-800 series) in July 2013.
Horize P151EM1B Clevo is the laptop model number.
win 7 64 bit
i7-2720QM
unknown
4gb
HD 5600 series
onboard sound
1366x768
Western digital
10 mbps down/0.8 up
Firefox/IE
Never heard of it. :(
Intel Core i7 6700K
AOC G2460PG
