Hard Drive Problem. Need advice
Blizzerd
11:17 AM
Ok, my computer HD recently had an accident.
I accidentally dropped my laptop, the hard drive started to act weird. None of my OS's would boot until i did scan disk, and then it worked. but if I do anything on one of my partitions, drive (D), the HD goes "Click.. click.. click"
I used " Chkdsk /r " in command line to see if I can skip over those areas, thinking they were bad sectors, but it doesn't work.
My HD never clicks anywhere else, only on drive (D)
Will my HD last if I don't use drive (D)? Or should I buy a new one ASAP?
acer 5720z
Xp, Vista, 7
intel Pentium Dual Core
Acer
2 gig
Intel 965 chipset
integrated
Laptop Display
1280 x 800
Western Digital 250 Gig
fan
HP wireless
depends
I'd back my stuff up and get a new one ASAP. Clicks from a HDD are NEVER good.
Home built
Phenom II X4 955 BE
Asus Sabertooth 990FX
8 GB OCZ BE 1667
EVGA GeForce GTX470 SC
BenQ 19"
1280x1024
256 GB OCZ Vertex 3 SSD
2x WD 1 TB
1x WD 2 TB
Thermaltake 850W
Coolermaster Cosmos 1000
Air
Cyborg R.A.T 7
Standard RR
+1 .. that drive has taken a fatal hit.. backup and replace... sorry :(
LENOVO K450 @3.0GHZ
64-bit Windows 8.1 Pro
LENOVO
12.00 GB
Intel(R) HD Graphics
Intel HD integtrated
HP 25' ISP Monitor
100mb down/10mb up
Backup your data.
A low level format will give your hard drive more time, but failure is imminent.
DELL VOSTRO 3650
Windows 8.1 PRO
3rd Generation Intel Core i7‐3612QM CPU @ 2.10GHZ
8GB DDR3
NVIDIA GeForce GT 525M (128 bit), 1GB Grpahics
1920X1080
750GB 5400RPM
