Solved Hardware t%l and 3D Problem HELP
djdecks2
3:15 PM
Ok i ran a test on system requirements lab about a week or two ago and it all passed threw the roof then a couple of days ago i ran a test and it said that my video card didnt have Hardware t%l and 3D
I have a ATI radeon hd 5740 on a pavilion dv6 hp laptop and i know for certain mine has both and i remembered a few days ago i got a display driver update which my of caused the problem.
but i have tryed reinstalling and trying old drivers etc and nothing has worked so i was thinking mayby i uninstalled something ati that i wasnt meant to
So for past two or three days i have been downloading updates vga drivers audio graphics all sorts of stuff to try and get it to work and before you ask i no for certain this is definataly not a hardware problem.
Hewlett-Packard HP Pavilion dv6 Notebook PC
2.27 gigahertz Intel Core i5 M 430
2934 Megabytes Usable Installed Memory
ATI Mobility Radeon HD 5470
AMD High Definition Audio Device
Intel(R) HD Graphics
It's hard to understand what you wrote. Maybe using some commas and dots could help.
Windows 7 Ultimate x64 SP1 clean install
AMD Athlon 64 X2 6400+
Asus M2N-E SLI
2 x NVidia Geforce 8600 GTS
Trust 5.1 Surround USB
Benq FP931 19"
1280x1024@32bit@75MHz
1 x Western Digital 500GB SATA (OS installation), 2 x Seagate 320GB SATA, 1 x Seagate 250GB IDE (in external USB box), 1 x TrekStor 750GB USB
650W
Logitech Cordless Desktop EX 100
Logitech Cordless Optical
8192 kbps / 640 kbps
Windows 7 Ultimate X64 SP1
ASUS P8Z68-V PRO/GEN3
Onboard Realtek 5-1
Samsung P2570HD
Corsair HX650W
Inwin Dragon Rider
Norton Internet Security 2013
no ive had it for a long time and system requirements lab tests games to see if they will run on your computer
Through Windows Update no doubt. If you can do a System restore to before the video driver update, that should get things back to normal. If it did come through WU and a system restore fixes it, make sure to not allow WU to automatically install any driver updates or it will happen again. Also means do not install any video driver updates manually if offered either.
Also if that laptop uses switchable graphics; uses the Intel graphics for low power regular use and the AMD graphics for gaming/etc; then you cannot use the regular AMD drivers as they have not been modified to work with the switchable graphics. If it is the switchable graphics then you can only use the drivers from HP (drivers because it takes both the Intel and the AMD drivers to work properly), and not the reference drivers from AMD or Intel.
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Onboard Realtek 5-1
Samsung P2570HD
Corsair HX650W
Inwin Dragon Rider
Unfortunatly i dont have a point before the update and yes it was windows update which i have now stopped.
also how do i tell if i have switchable graphics i have like high performance or save battery settings which at the moment its at high performance but im not sure if i have switchable graphics.
ok Britton30 ill try that
Without knowing the full model number (HP has recycled the dv6 for a while now, and there is something like 100 variations of it), Device Manager should show both the AMD and Intel. You should also have (when things are working properly) both an AMD and Intel control panel.
This isn't your laptop based on the specs but it is close,
HP Pavilion dv6-3073ca Entertainment Notebook PC (XA667UA) specifications - HP Home & Home Office Products
and it does have the switchable graphics,
ATI Mobility Radeon HD 5650 switchable graphics with 1024MB DDR3, up to 2714MB total graphics memory
So if yours is the same then you need to look it up at HP and get whatever they have for the latest driver for both. Might be able to get away with just downloading what they have for the AMD driver as HP and most of the other laptop manufacturers tend to include/integrate the Intel driver into the AMD install package.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
You shouldn't stop Windows Update, but have a look at what it is recommending, and UNcheck hardware drivers. WU is usually behind on them, go to the hardware device's support page for drivers.
What do you mean by switchable graphics?
EDIT: Greg beat me to it.:)
Onboard Realtek 5-1
Samsung P2570HD
Corsair HX650W
Inwin Dragon Rider
This is the driver you need for it,
AMD High-Definition Graphics Driver HP Pavilion dv6-3060sa Entertainment Notebook PC - HP technical support (United Kingdom - English)
and it already has the Intel integrated into it,
Provides Intel Graphics Driver version 8.15.10.2189 (in addition to the AMD Graphics Driver) to support the Intel GPU in notebooks with switchable graphics.
Before installing it go through Programs and Features and uninstall any AMD or Intel graphics entries, then run it and see if it will install.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
couldnt find any intel or amd stuff and no its didnt work the screen flashed a lot and i checked but same problem should i perhaps use driver sweeper and then use it?
Ok i completly reinstalled my OS then that driver ive ran the test it says i have both things back so im installng fallout 3 to see if its working
Nope still not working sigh anymore ideas?
You have no video?
Onboard Realtek 5-1
Samsung P2570HD
Corsair HX650W
Inwin Dragon Rider
No the game just stutters like crazy all games do
I have the same, a HP DV6 laptop with a i5 cpu and ATI 5470, I don't think the ATI 5470 has Hardware T&L as doing some research into it I cannot find anywhere that it has it and I find can you run it scans to be very accurate anyway, especially as I talk to some ppl who work there. The graphics on the i5 cpu does support T&L as it says so on intels website however this graphics isn't very good at gaming.
HP DV6
Windows 7 home premium 64 Bit
Intel i5 460m
6GB DDR3
Intel GMA and ATI 5470
15 inch Monitor
500GB
FC360, welcome to the Secen Forums.
IOf course the HD 5470 has T & L, it just isn't called that any more and hasn't been for a long time. All cards now have unified shaders which replaced the separate pixel and vertex shaders, which in turn replaced T & L.
Shader - Wikipedia, the free encyclopedia
You have to go back to the old Geforce 2 and 4 MX series of cards to find a card that listed T & L instead of pixel and vertex shader versions. Intel is likely still listing in their specs just to look different, as everyone knows that Intel graphics still aren't good for much.
The HD 5470 being a DirectX 11 GPU uses shader model 5,
ATI Mobility Radeon
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
ATI Mobility Radeon
Oh I didn't know that hehe maybe that's why the can you run it scane says the card doesn't have T&L then :) and thanks for the welcome :)
HP DV6
Intel i5 460m
6GB DDR3
15 inch Monitor
500GB
