hdmi audio nvidia g100 problem.. HELP
sogone209
2:20 PM
Eugene, Oregon
ok my computer is acer aspire x1700 and it comes iwth a discrete nvidia geforce g100 video card with HDMI output,when i hook it up tomy tv theres no audio. but if i use the motherboard hdmi it has audio, how do i get my NVIDIA TO PLAY AUDIO. plz help i have the latest drivers
gameing build
Windows 7 Professional x64 (6.1.7600)
Amd Athlon ii x2 255 3.1 ghz
asus m4a89td pro/usb3
4Gig Dual Channel DDR3 PC2-1300
Amd Radeon HD 6670 1GB DDR5 256bit
Toshiba Lcd 40inch Tv
1920x1080 60htz
Hitachi HDS721010CLA ata 1TB 7200Rpm
Cooler Master GX 550W
Cooler Master Silencio 550
Two 120mm fans, with stock heatsink with 140mm fan on top
20MBps
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
i dont see spdif in the sound or realtek audio panel. it says realtek audio optical when i plug in the hdmi to the g100 graphics card. but when i but the hdmi from the motherboard using the motherboard internal video it says the aduio is using nvidia hdmi for sound. but it never says that for my g100 card. i have realtek and 266.58 drivers the newest ones. and i know it has spdif for sound it says on the specs of that video card on nivdia website
gameing build
1920x1080 60htz
20MBps
im just trying to get video and SOUND from the hdmi cable connected to my g100 card, cause thats how it works when i plug it into the MOTHERBOARD HDMI AND USE THE MOTHERBOARD VIDEO CARD instead of the G100 card attached to the pci slot.
gameing build
1920x1080 60htz
20MBps
That video card does not have any built in audio. To get audio over HDMI from it it has to have a SPDIF cable from it to the SPDIF header on the motherboard (or sound card if one is used instead). As a result it uses whatever driver is installed for the onboard audio which when you say,
then it is switching to the correct setting (SPDIF is digital).
Seeing as Acer conveniently provided instructions on what to check inside the computer when the HDMI audio doesn't work, follow that link I posted and check the cable and connectors, and reverse it as shown.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
the spdif and ground is exactly like the picture. but i dont want to use 2 cables for video and sound. doesnt sound travel threw hdmi cords? THE CONNECTERS ARE FINE. and audio is enabled on my nvidia control panel its 1600x1800 1080p (audio enabled) but dont hear soundthrew tv? LIKE THE OTHER HDMI PORT ON MY COMPUTER MOTHERBOARD :( on the realtek audio digital it shows sound on the sound meter going up and down like theres sound but no sound to the tv via threw the hdmi from the g100.
gameing build
1920x1080 60htz
20MBps
Then disconnect them and switch them around. Just because it matches the picture doesn't mean it isn't connected backwards on the video card.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
ok i switched them twice, so are you for sure saying that i can get AUDIO from my nvidia geforce g100 video card via HDMI cord? i dont gotta use 2 cords? hdmi for video and then a audio cord for sound?cause i just wanna use the hdmi for video and sound, so it should work switching those wires around? i tried twice maybe the connection at the top of the card is loose and not connecting. ill see
gameing build
1920x1080 60htz
20MBps
