HELP! ethernet cable not being detected
Hazza
12:37 AM
I am using windows 7. i have upgraded from vista recently.
My internet connection has been cutting out infrequently over the past month, but now it has cut out completely. windows is detecting the problem as a either a faulty ethernet cable or as a cable not being connected.
I have tried;
  • changing the cable
  • unplugging/plugging back in
  • unplugging/restarting/plugging back in
  • disabling/re-enabling the device
i am connecting using 'Realtek PCle Family Controller'
The modem is a D-link
Very appreciative of any help on the matter
First, update your drivers. Either thru your driver CD or by downloading the latest and copying and installing using a USB.
If all done and still issue, check in your DM whether the network adapter has no issue.
MacBook Pro
Lion
i5
4GB
Intel
1200x800
Seagate FreeAgent GO 250GB Ext. HDD
drivers are updated... whats DM? apologies for noobness
Device Manager. BTW, When you connect the cable, wat does the network indicator say?? A red cross mark???
What about the lights in your Modem? All Lit?
If you have a spare desktop or laptop, can you check whether the network line from Modem works??
MacBook Pro
Lion
i5
4GB
Intel
1200x800
all the lights are lit on the modem. Internet is working on another desktop and on a laptop.
The network indicator has a red cross on it yeah. it just seems to not be detecting the cable at all
You say other computers work - can I assume then you have a Router? Ports can go bad. Try another port. If it works in another port, it may be totally bad, or just needing a router reset (power cycle for 10 seconds or so).
BrightWorks Systems B4
Windows 7 Profession 64-bit
Intel Core i7-860 Quad
Gigabyte P55-UD4P
Mushkin 4x2Gb PC12800
Gigabyte GTX260 896Mb
Integrated 7.1 HD Dolby
2 Samsung 2220wm-HAS 22"
1680 x 1050 | 1680 x 1050
WD HE 1Tb
Corsair TX-750W
Ultra M998
OEM
MS Wireless Comfort 5000
MS Wireless 5000
Cable and pretty darn fast
Hazza, Welcome to SevenForums.
This sounds like a driver problem to me however if you have tried replacing your Network adapter drivers with no help and need a quick fix without opening up you computer then you may like to try a usb adapter.The network cable plugs into it and it goes into a usb port. I keep one around in case a nic card goes bad. Good luck to you with your problem.
SMC EZ Connect Compact USB Adapter - SMC2208USB/ETH - Buy.com
Gateway GT5692
Windows 7 Ulti. x64
AMD Phenom 8450 triple-core 2.10 ghz
4GB
ATI Radion HD 3200
Gateway FPD1775W
1280x720
465.6613 Gibibytes
