HELP! Fable 3 Installation Problems D:
Roarke
4:42 AM
Perth, WA
I have recently received a copy of Fable 3 but i am having a very hard time of installing it due to constant errors. When trying to install it from the disc i get an error message that says:"An error has occurred. Error code: 0x80096010". I have searched all over the net trying to find a solution but i have been unable to find anything. I also tried copying all the files off the disc into a file on my desktop and trying the installation from there, this installation from my desktop gets further into the installation before stopping and giving me an error message: "An error has occurred. Error code: 0x800b0100". Please help if possible, I am running Windows 7 Home Premium, 64-bit. Thank you.
Austin Computers, Custom
Intel Core i5-2400 CPU @ 3.10GHz
ASUSTeK Computer INC. P8H67-M
2 x 2048 Mb, DDR3, 669 Mhz
Radeon HD 5770, 1024 Mb
23" LG, LCD, HDMI
1Tb HDD
Cooler Master
Fans
Razer Lycosa
Razer Mamba
iinet, Dsl
Have you tried running the setup with Admin rights? If not, that might be why. Some game setup.exe files won't work right without Admin rights
Windows 7 Ultimate 32-Bit
Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Gigabyte Technology Co., Ltd. EX58-UD3R
Corsair DDR3 4Gb
Nvidia Ge-Force GTS250
High Definition Audio Device
Envision 19 inch
1280x1024
2 physical hard drives (4 letter drives) that equal up to 626.3 gigs of space all together. I think both are Maxtors, but primary is a SATA drive, secondary is a SATA, too.
"Elite" style case
"Cooler Master"
Microsoft Optical USB Mouse.
Verizon DSL Internet
Something similar happened to me a very long time ago when I tried installing Call of Duty: World at War using a physical disk that I had purchased from GameStop. It seemed the disk was just "bad" or corrupt which seems extremely unlikely if the product is brand new but I guess it can happen. If you got it from a store then I recommend you go back and tell them it's defective and they should offer to replace it. If you got it online then contact support and tell them the same thing.
Windows 7 Ultimate 64-bit
Intel Core i5-3570k @ 3.4GHz (OC to 4.0 GHz Turbo Boost)
MSI Z77A-G45 LGA 1155 Intel Z77 ATX
ADATA XPG Gaming Series 8GB DDR3 1600MHz (2x4GB)
2x EVGA GTX 770 2GB Superclocked w/ ACX Cooling
On Board
1x ASUS VG248QE 24" 144Hz 1ms LED-LCD 3D Ready
1x Corsair Force Series 3 90GB SATA III SSD (OS);
1x Kingston SSDNow V300 Series 120GB SATA III SSD;
1x Hitachi DS7SAC100 1TB 7200 RPM 32MB Cache SATA II HDD;
1x Hitachi DT01ACA300 3TB 7200 RPM 64MB Cache SATA III HDD
EVGA Supernova 1000 P2 1000W Fully Modular Platinum Rated
Rosewill Thor V2 White Full Tower
CM Hyper 212 EVO (Push); 2x Intake 2x Exhaust Fans
Tt eSports Poseidon Cherry MX Brown Mechanical Keyboard
A4Tech X7 F5 Wired Laser Mouse
120 Mbps down, 40 Mbps up
MSE, Malwarebyte's Anti-Malware Premium
ASUS RT-N66U Dual-band N900 Gigabit Router;
Netgear WNDA4100 Dual-band N900 USB Adapter
Thanks for your replies, I have tried to run with admin rights and it gives me the same result as well as trying to change compatibility to Windows XP SP 2/3. I strongly think that there is something wrong with the digital download so I will try to contact support and see if they have had others with the same problems.
23" LG, LCD, HDMI
1Tb HDD
Cooler Master
Fans
Razer Lycosa
Razer Mamba
iinet, Dsl
