unclechris50
- Local time
- 1:37 PM
- Messages
- 2
My computer=Win 7 64-bit (Program file x86)
Warning 20225. Adobe Acrobat 7.0 Setup was unable to create a new item: Adobe PDF Port_Printer. The Adobe PDF Printer may be unavailable. GetLastError: The operation completed successfully.
From previous posts relating to this subject that i have read, there seems to be no solution yet.
In the add a printer option, under -> Add a local printer -> Use an existing port:
On the "Use an existing port" pull-down menu, there is no option "Documents\*.pdf (Adobe PDF)".
The folder C:\Program Files (x86)\Adobe\Acrobat 7.0\Acrobat has no subfolder Xtras, and there is no file AdobePDF.inf anywhere in the whole tree C:\Program Files (x86)\Adobe or anywhere on the Acrobat 7.0 distribution CD.
Any prompt needing suggestion will be appreciated. Reply ASAP
- windows 7 Home basic, 64-bit OS. (Program files x86)
