Welcome
First dont use software to do the job that the computer owner can easily do.
Go back with system restore.
http://www.sevenforums.com/tutorials/700-system-restore.html
When your computer is up and running, get rid of the software that is doing what you should be doing.
To maintain your computer
10 Tips on How to Properly Maintain Your Computer
Steps that I did not notice on the guide include:
Running a scan disc before doing a defrag
Using Microsoft Security Essentials and Malwarebytes.
Making System Restore points, at least once a week
Makaing a system Image once a month (varies by user)
Not relying on your A/V common sense, should prevail. You know of many sites can cause a problem.
Do not use any reg cleaning or optimizing software.
Download and use Ccleaner about once every two months. Untick any registry entries.
http://www.piriform.com/
If you follow these instructions, you will be trouble free for a long time to come.
Be sure to back up your hard drive about once a month (varies by user) and to keeep system restore points up to date.
Optimize Windows 7
