Help-How pin more shortcut per group
jogger912
1:59 PM
Help-How to diplay more pinned shortcuts per group
I use Excel a lot, i have about 25 files shortcuts that I use frequently and i need to pin to the taskbar. I am using the grouping method and i like it a lot.
Currently I have reached the max i can see when i right-click on my Excel Application on the taskbar. I have 19 Excel files pinned, when i pin 1 more, #20 goes to the bottom of the list and I can't see it. If i remove one, then #20 shows up.....this is not a screen limitation bc the list displayed only uses 2/3 of my screen height. so there is a lot more screen to expand onto.
Is there a way to increase the number of pinned shortcuts that i can see on my screeen when i right-click on the taskbar button?
HP Touchsmart Notebook tm2t 2100
windows7 x64bit
Intel i3
4GB DDR3
Intel HD Graphics with up to 1695MB total graphics memory
Lenovo IdeaCenter 450
Windows 10 Pro X64
Intel Integrated HD Graphics
HP 22" LCD
250GB Samsung EVO SATA-3 SSD
Dell USB
Lenovo USB
Seamonkey
UEFI/GPT
PLDS DVD-RW DH16AERSH
