HELP!!internet connection problem
plout
10:34 PM
Hello guys and thanks in advanced.
Well i've recently bought a sony vaio and i used my modem dsl-320b modem ethernet and connected to the internet without problems.---> windows 7 home premium OS
After 1 week i have this problem..i can' access to any browser..mozilla o explorer 8,but it does connect to Skype:sarc:.....
i've noticed that the LAN sign is not constant and when i put ethernetn cableback to my older pc with OS windows xp i can connect to the internet without problems at all...any suggestions????
Thinking to change modem..because i read is compatible with vista,not 7.
windows 7 home premium 64bit
We need a bunch more information before we can help you.
Whats you network setup, are you using homegroup? also type cmd in search, then type ipconfig /all. make a screenshot of the results and upload it to us.
Ken
EDIT: Is this on a virtual machine?
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
i have prob to screenshot..as i select all can't take more action cause i can't connect to internet and doesn't let use office.
don;t know how to post this thing..
Error:unrecognized or incomplete command line
usage:
ipoconfig[/allcompartments] [/? :/ all
/renew [adapter] : /release [adapter] :
/renew6 [adapter] : /release6 [adapter] :
/flushdns : /diplaydns : /registerdns :
/showclassid adapter [classid] :
/setclassid adapter [classid] :
/showclassid6 adapter :
/setclassid6 adapter [classid]
where
adapter conection name
<wildcard characters * and ? allowed, see examples>
options:
/? Display this help message
/all Dispaly full configuration information.
/release Release the IPv4 adress for the specified adapter
/realease6 Release the IPv6 adress for the specified adapter
/renew Renew the IPv4 adress for the specified adapter
/renew6 Renew the IPv6adress for the specified adapter
/flushdns Purges the DNS Resolver cache
/registerdns Refreshes all DHCP leases and re-registers DNS names
/diplaydns Display the contents af the DNS Resolver Cashe
/showclassid Displays all the dhcp class IDs allowed for adapter
/setclassid Modifies the dhcp class id
/showclassid6 Diplays all the IPv6 DHCP class IDs allowed for adapter
/setclassid6 Modifies the IPv6 DHCP class id
The default is to display only the IP address,subnet mask and default gateway for each adapter bound to TCP/IP
For Release and Renew,if no adapter name is specified,then the IP adress leases for all adapters bound to TCP/IP will be released o renewed.
For Setclassid and Setclassic6,if no Classid is specified,then the ClassId is removed
Examples:
>ipconfig ...show information
>ipconfig/all ...show detailed information
>ipconfig/renew ...renew all adapters
>ipconfig /renew EL* ...renew any connection that has its name starting with EL
>ipconfig/release *CON* ...release all matching connections
>ipconfing/allcompartments ...show information about all compartments
>ipconfing/allcompartments/all ...show detailed information about all compartments
C:/users/mina>
network setup..what do you mean.I use only one laptop ..home connection
just let you know that simly i insert the ethernet cable on laptop's gate and didn't configurate anything.
usage:
where
options:
Examples:
C:/users/mina>
We need something that looks like this
Where are you having problems?
ken
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
ok i found it....hmmm can you tell me what to post...it will take ages....unless you use skype,i send it to you from there.....
No skype sorry. I have any IM client.
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
Hello Plout,
Welcome to Seven Forums.
You can highlight everything in the command window that you want to paste here and then right click on the title bar of the command window. Select Edit/Copy. This will put it all on the clipboard. Then select the # sign in the reply and hit ctrl+V to paste the contents of the clipboard between the Code tags. That should paste everything here for us to read.
Gary
Dell XPS420
Creative SB X-Fi audio
HP w2207 + HPvs15
1680x1050 + 1024x768
2-WD5000AAKS-500 GB
WD5000AAV-500 GB external
Microsoft Comfort Curve
MX Revolution
Experience Index=5.5
Thank you guys...well i don't know if I did well,but i've noticed that when I was trying to log in to messenger was missing the DNS...so a friend of mine gave me 2 different numbers of DNS to to enter on the TCP/IPv4 and everything wokrd after that.
Any suggestions or ideas if was some kind of spyware or trojan??I did a full scan with McAfee antivus and Malwarebytes' Antimalware....and nothing found.Do you think is going to be repeat this problem?
