help me I have dual monitor problem......
kudoz
4:03 PM
i was set up dual monitor / it has a DVI port and a RGB port
usually dual monitor is good working
Here is my problem : after into standby mode? I wake up computer monitor
but dual monitor doesn't working....just changed dual monitor system to single
monitor system(second monitor is blank and first monitor isn't working)
what's the problem?? driver problem? (i was set up least driver on nvidia)
i think OS problem.....
what's the solution about this a problem?
windows 7 professional k 64bitintel corei5 2500samsungm ddr3 4Gnvidia 440gts
pc
intel corei5 2500
asus p8h67 b3 revision
samsungm ddr3 4G
nvidia 440gts
integrate
LG w2453vp
1920*1080
samsung HD103SM
standard 500W power supply
GMC
basic cooling
samsung
samsung
100mbps
this computer set up at 2011-11-28
Hello Kudoz, and welcome to Sevenforums.
I hope I may offer some kind of solution to your problem. I doubt it is an OS problem, but let us troubleshoot it and see where that takes us. When you say you put your computer into standby mode, do you mean sleep mode, or do you mean hibernation? I do not think Windows 7 has a "Standby Mode" unless you are referring to one of the aforementioned modes. Do both monitors work when you restart (or shut down/turn on) the computer?
Have you installed the lastest updates from Windows Update? If you need updated drivers, please fill out your specs according to the following method, as I am not entirely sure what some of the items you have listed in your System Specs are at the moment:
New to SevenForums? Fill out your system specs (this tool may help you out a great deal).
Microsoft Windows 8.1 Pro 64-bitIntel(R) Core(TM) i3-4130 CPU @ 3.40GHz8.00 GBNone
Custom Asus Build
B85M-E
8.00 GB
None
Asus 23.6" Monitor
INTEL SSDSC2BW180A4
Samsung SSD 840 PRO Series
Seasonic S12II-380Bronze
Lian Li
Fan, Passive
Logitech K120
Microsoft Touch Mouse
Eset Endpoint
Internet Explorer, Chrome
ah~ i mean standby mode is sleep mode;;; i didn't think that word.
my windows update version was latest version before i write this question also same graphic driver version.
and i fill out exactly my system specs
ah my both moniters good works when i restart the computer
thank you for your interest
pc
intel corei5 2500
samsungm ddr3 4G
nvidia 440gts
integrate
LG w2453vp
1920*1080
samsung HD103SM
GMC
basic cooling
samsung
samsung
100mbps
ah i mean standby mode is sleep mode i didn't think that word.
Would you mind disabling hybrid sleep mode and seeing if sleep mode works on its own? Follow this tutorial but disable anything that mentions hibernate or hybrid sleep. also, to see the available sleep states on your computer, follow this tutorial. Post back what you find.
Custom Asus Build
B85M-E
8.00 GB
None
Asus 23.6" Monitor
INTEL SSDSC2BW180A4
Lian Li
Fan, Passive
Logitech K120
Eset Endpoint
Also what is the model of the second monitor, i have a NVidia gts 250 and my main monitor is in the dvi plug and second monitor is plugged into the vga plug and they just work. Not sure what you have on the 440, but should be comparible, either 2 dvi or 1 dvi and 1 vga. Do you have the latest drivers from NVidia 285.62.
Windows 7 Home Premium 64 bitIntel Core 2 quad Extreme Q9770 @ 3.2 GHz4x2 GB Muskin 1600 MHz ramNVidia GTX 250
Dell XPS 730
NVidia GTX 250
Soundblaster X-Fi Fatality Champion
2 Dell 2007WFP Ultrascans
3360 x 1050
WD Black 1TB sata, 2-WD Black 500 sata, 2-Seagate 500 Go external
1000 Watt
air
MS Natrual Keyboard Pro
Logitech Wireless Trackball
DSL Elite
i was knew that way.... i want to use sleep mode but if i do follow your tutorial that i don't use sleep mode....
thank you for your solution but i want to fix this bug
pc
intel corei5 2500
samsungm ddr3 4G
nvidia 440gts
integrate
LG w2453vp
1920*1080
samsung HD103SM
GMC
basic cooling
samsung
samsung
100mbps
Kudoz,
You can still use sleep mode this way, it just won't be hybrid sleep. There usually isn't a need to save your session to the hard drive (Hybernate) & put the computer into a low powered state (Sleep). I would choose one or the other (Hybrid combines both).
Would you try it to see if this may be the problem you're having? It may help me understand the problem more if you do. You can always switch back to hybrid if you are still having problems
Custom Asus Build
B85M-E
8.00 GB
None
Asus 23.6" Monitor
INTEL SSDSC2BW180A4
Lian Li
Fan, Passive
Logitech K120
Eset Endpoint
