Help me to use full speed my WiFi connection ( WLAN)
killer bee
Power User
8:53 PM
I have 135Mbps link speed support ADSL WI-FI router. I have enabled 802.11b+g+n wireless mode and use 20+40 MHz on my router. I use "WAP-PSK" authentication. In addition to that, have a 2.4 & 5 GHz frequency support router and client device.
But my network connection display (WLAN) I have a 54Mbps link speed, why is that? How do I use 135Mbps or at least 100Mbps link speed? Is it a some configuration issue? My Ethernet connection show full speed (100Mbps).
(I'm not talking about my internet connection speed).
windows7 Ultimate SP1 x32bitIntelKinsgton 1GB an Transcend 2GBIntel- onboard
Intel DG31PR (Intel Dual core 2.5 E5200 @ 2.5GHz)
Intel
Intel DG31PR
Intel- onboard
Intel- onboard
ViewSonic LCD Widescreen 19
1400x900
Samsung 256GB
Legend
Legend
Intel
Seemo
Prolink
Download Speed-512Kbps, Upload Speed-128Kbps (ADSL wired)
UPS- Prolink Pro650s
Router Prolink H5201
Sub Woofer - Creative 2.1
Brand and model of the router and the wifi card or usb thats in your PC might help, thanks.
Windows 7 Ultimate x64Intel Pentium Dual Core E5200 2.5GHz (3.77GHz...Corsair 4GB DDR2 (4x1GB CM2X1024-6400C4)Palit GeForce GTS 250 (1024MB)
Self built
Intel Pentium Dual Core E5200 2.5GHz (3.77GHz OC)
Asus P5Q-E
On Board (ADI AD2000B 8ch HD)
Samsung 32in LCD TV
1360x768
2 x 1TB Samsung 103SJ (Raid0)
2 x External 500GB Samsung 502IJ (NexStar 3 HD Enclosures)
550W Antec Neo HE 550
Antec P180
Xigmatex Red Scorpion CPU Cooler. 3x120mm Fans
Logitech MX5000 Laser (Combo)
ADSL2+ (avg 10 Mbps Down, 0.80 Mbps up)
Gigabyte GN-WP01GS 54g Wireless Lan Card
Windows 8 Pro x64i7 3820 @ 4.68GHzF3-12800CL9D-8GBXL (32GB)GTX 480 SLI
Windows 8 Pro x64
i7 3820 @ 4.68GHz
ASUS Rampage IV Extreme RoG BF3
GTX 480 SLI
Auzentech X-Fi HomeTheater HD
Sony 32V5500
LSI MR9260-4i (RAID10):
Toshiba DT01ACA300 x 4
iaStorA:
OCZ Vertex Enterprise 120GB
ST3500320AS 500GB
Intel 520 Series 120GB
OCZ ZX 1250W
HAF X
H80
Cyborg V.7
Razer Lachesis 3.5G 5600dpi
23296kbps ds / 812kbps us ADSL2+
Mozilla/5.0 (Windows NT 6.3; Win64; x64; rv:32.0) Gecko/2010
AverMedia C127 Game Broadcaster HD
People look at advertised speeds and think that is what they should get, when in fact, it is more complicated than that. Different 802.11 standards have different bandwidth capacity and your Wireless LAN will only run as fast as its lowest 802.11 standard, eg. 802.11a/b/g/n. What that means is if you have a device that runs off of 802.11g standard, your wireless network will not be able to run any standard above 802.11g. LuzTeTT's comment above is correct.
Windows 7 Professional 64bit SP1Intel Core i5-3570K @ 4.5GHzCorsair Vengeance 16GB (4x4) @1866MHz CL 9-9-...EVGA GTX 750 Ti FTW
Asus Sabertooth Z77
EVGA GTX 750 Ti FTW
Onboard Audio
Dell S2309W
Samsung 830 128GB SSD - OS
(4) Seagate 5TB HDD
(1) Seagate 2TB HDD
Intel Liquid Cooler
Mionix Naos 7000
50 Mbps Down / 10 Mbps Up
Chrome/Firefox
Klipsch ProMedia 2.1's
Asus RT-N66R Wireless Router
IEEE 802.11 - Wikipedia, the free encyclopedia
It looks like your device is running at 802.11g and nothing further.
Thank you friends your replies, after adjust some settings on my router, now I got 72Mbps link speed. Still I'm not received 40GHz connection. I used 802.11b+g+n mode.
Yes friend, I have 802.11n support client device, I think its something a router settings issue. Now I got 72Mbps.
Intel
Intel DG31PR
Intel- onboard
Intel- onboard
1400x900
Samsung 256GB
Legend
Legend
Intel
Seemo
Prolink
You need to change over to 802.11n Only mode, this will only work if you don't have any wireless G or below clients that need to connect. Using the mixed modes is what's holding you back
Channel bonding 20mhz-40mhz is also needed but it does require good signal strength.
To get the max speed possible you will also want to check out the wireless channels being used in your area then make adjustments to your channels in the routers settings to use channels that aren't being used by any neighbors.
With 802.11n USB dongle the best you can get is 300Mbps, using a PCI slot NIC up too 450Mbps is possible.
With the new 802.11ac 1.4Gbs or more is possible.
This link goes over the process and the required adjustments.
http://www.eightforums.com/network-sharing/10053-wifi-status.html
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
GSkill Phoenix Pro 120GB SSD
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
