Help - Network usb adapter connection to router problem
McSeven
3:02 AM
I have a Verizon router and I purchased a NetGear N900 wireless dual band usb adapter for my son's computer. I was going to test the N900. It is for college.
The N900 will not connect. I do have three other laptops that do connect and work ok. The N900 has WPS but the Verizon router does not.
So I have to use the SSID, 'wep' option, and the wep key. The N900 tries to connect and stops trying after about 20 seconds or so. The N900 varies from 4 to 5 green bars. Any ideas on what might be wrong? :confused:
N900 installation was followed and went smoothly and the new software version was used. We are using Windows 7 Home Premium 32bit on my son's computer.
I also purchased the Western Digital My Net N750 router for college. I have no way to test everything at home. It does have WPS so at the college I hope everything works.
W7 Prof 64 biti7-3770kG.Skill Sniper 1866 16 GBEvga GTX 770
HomieJunker
W7 Prof 64 bit
i7-3770k
Sabertooth Z77
Evga GTX 770
Sound Blaster Z
Asus VG278HE
4 Seagate Barracudas 250 GB
2 Intel® X25-M 160GB
Corsair H1000X
Lian-Li A77B
Phantek 120 dual fans
Corsair K70 RGB
Logitech G502
FiOS Quantum
Avira
Change security to WPA2 AES and install the setup wizard from Netgear.
Win7 Home Premium x64 W10Pro&HomeA12 9720p 4+8 TurionII M5206GB 8GBR7
HP 17-ak0xx, dv7 3173nr
HP 3839
6GB 8GB
R7
24" sa550
1600x900 1920x1080
Logitechx2
120Mb/s down 12up
Thanks very much!
HomieJunker
W7 Prof 64 bit
i7-3770k
Sabertooth Z77
Evga GTX 770
Sound Blaster Z
Asus VG278HE
Corsair H1000X
Lian-Li A77B
Corsair K70 RGB
Logitech G502
FiOS Quantum
Avira
