HELP!!! Problem with resolution on taskbar...
hopeisb4u
11:41 PM
Hi everyone! This is my first time to this forum. I was looking for someone that has the same problem as me online, and found this forum. I'm hoping someone here can help me. I bought a new laptop last week with 7 on it, I love it. However, while i'm online, it seems my as if the resolution in the task bar keeps messing up. Whole lines, or blocks, or I'm not really sure what you'd call it keep turning funky shades, and stuff. I assumed it was the computer, and took it back today for a replacement. But, the new one I just got today is doing the same thing. I tried to recreate the problem to post up here, but you know how that goes!!!! :(
Any help would be greatly appreciated.
windows 7
Hi and welcome
It would be easier if you could take a screenshot and upload it to us.
You can do that by using the built in snipping tool (just type snipping in search) and then to upload use the attachment icon (its shaped like a paperclip) in the reply form
Let us know if you need help with that
Ken J
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
What browser are you running? Since you mentioned that it happens "when you are online", does it happen at other times?
Are you running software supplied by the manufacturer?
Ski
Hp Pavillion Dv9500t
Windows 7 Professional
Intel Core Duo T7500 @ 2.2GHz
4Gb
Nvidia 8600m
Ken -
that would be great if I could...but each time i touch it, when it is messed up, it goes back to the way it should. At this point, I don't know if it is a windows issue, or an hp issue.
windows 7
Ski
Ski i'm using internet explorer, and yes...it is what was on the laptop
windows 7
Maybe this has something to do with the transparency, or a particualr program your using..
W7 RTM Ultimate x64
Intel Q8400 @ 2.66GHZ
Gigabyte GA-EG45M-UD2H
4GB DDR2-800
Integrated 8 Channel
AOC 23.6 Inch Widescreen LCD
Seagate 500GB Internal
Western Digital 1TB Internal
Hitachi 1TB External
Apevia Java Power 500W
Cooler Master HAF 922 Black
Stock Intel CPU Fan
1.5MB
So, it ONLY happens when you are in internet explorer AND you are not touching the PC? Does it occur right away or does it take a while to begin goofing up? Is IE in full-screen or windowed mode?
Since this has occurred on two brand new computers I suspect its a problem with your HP. I would make sure that you have all of the latest drivers downloaded and installed. If the problem still occurs you might want to see if the issue occurs with another browser (Mozilla Firefox would be my choice). Call HP tech support and check the HP forums.
Ski
4Gb
Nvidia 8600m
Ski ~
It has happened when IE is on full screen. To clarify, when it happens, I am using my PC, however the task bar corrects itself when I click on the distorted bar, that is why it seems impossible for me to show anyone, unless they are here when it happens. I worked some last night not in full screen, and it didn't seem to happen.
thank you for the advice, and I will surely check out some HP forums.. I really don't want to have to go shop around for another new computer!! lol
windows 7
