Hello.
Here's the thing...
I was using my StoreJet fine, when finished using I removed safetly and everything.
But when I go to use again, it starts making a beep with the LED indicator off, the beep stops after a few seconds and the LED indicator turns on. It's working but doesn't appear in My Computer so I can use it. How can I fix it without lose the data in it (I got some important data that I need asap!)
I tried to be clear as possible, I'm desperate!!!
Thanks for any help.
Here's the thing...
Windows 7 Pro 64-Bit
- Computer type
- PC/Desktop
- HP
- Windows 7 Pro 64-Bit
