Help Setting a Permanent "Default" Audio Output
iiTz STeVO
1:43 PM
I have a Samsung 24" monitor/TV combo as well a Turtle Beach X12 headset connected to my desktop at all times.
I have been experiencing issues with my computer always choosing the monitor as the default audio output. I believe it may be because my computer detects my monitor before it detects my headset.
Regardless, my computer seems to always choose the monitor for default, making me go into the sound settings and switch over to my headset. Then sometimes even after the switch part of my sound will play through the headset while a different application will play through the monitor.
I want to find a way to set my headset as a permanent default. Ideas?
AMD Phenom II Black Edition Deneb Quad-Core 3.4gHz
Corsair Vengeance 2x4GB
Radeon HD 7850 2GB
Mozilla Firefox
Did you disable the monitor under your Sound devices, in Device Manager?
...and in playback devices off the right click of the volume control, you should be able to disable it there as well, right click the offender and disable.
Self Built Custom
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
AMD FX-8350 CPU v1.15 (or 1.0F) BIOS was required!
MSI 890FXA-GD70
8G CAS-7 G-Skill DDR3 @1333 (2 fours) [mobo nonOC max rec'd]
Radeon HD 7950 [3 gigs of GDDR5] MSI Twin Frozr model
Realtek High Definition Audio (onboard mobo, ALC-889 chip)
2 WS LED Monitors: One LG One Viewsonic
1920 by 1080
SSD for OS: Samsung 840 Pro
SSD for VM and utilities: Adata SX900
7200 RPM SATA HDs for the rest: Hitachi and Seagate
Corsair TX850 - 850W max, in service since August 2010.
Thermaltake Armor A90
Thermaltake Spin Q CPU Cooler, in service since August 2010
Logitech G11
Logitech M310 Wireless
100 Megabit broadband supposedly upgraded from 50 (Cable)
Bitdefender Internet Security 2014 suite
Pale Moon 64-bit main, also IceDragon, Opera, and Maxthon.
CompTIA A+ certified (220-800 series) in July 2013.
Totally forgot about the ability to disable devices. Success!
Radeon HD 7850 2GB
Mozilla Firefox
