SOLVED! Help with common Hard drive RECYCLER problem...
Hello,
So my 1TB external hard drive was working fine but then all of a sudden I cant access any folders. When I try to open any folders in my hard drive I get this error:
Windows cannot find 'H:\RECYCLER\e621ca05.exe'. Make syre you typed the name correctly, and then try again.
The files that are not in folders works fine, just cant open folders.
I see many many people with the same problem, and fixed it by downloading a program called "Autorun Earter". But it doesnt find anything wrong. I also ran Malwarebytes and it found 4 things but after removing them, still doesnt work. It just removed some computer game stuff.
Anyone can help me?
Oh Im running win 7 64bit.
[Edit]
I also noticed that in the list of folders in my HD, there is one called "RECYCLER" and I can open that folder. There is also a folder of music before that Recycler folder and I can open that folder as well. But everything after the Recycler folder, gets the error.
Hello,
Anyone can help me?
[Edit]
- HP DV7-2185dx
- Microsoft Windows 7 Ultimate 64-bit 7600 Multiprocessor Free
- Intel(R) Core(TM)2 Quad CPU Q9000 @ 2.00GHz
- Motherboard
- Quanta 3624
- DDR-2 2.00 GB/ DDR-2 4.00 GB
- Graphics Card(s)
- ATI Mobility Radeon HD 4650
- Sound Card
- (1) AMD High Definition Audio Device (2) High Definition A
- Hard Drives
- FUJITSU MJA2500BH G2 ATA Device 465.76 GB
