HP 8300 error 515 power supply fan not detected after upgrading PSU
realflow100
9:01 PM
What do I do to bypass/ignore this error? I can SEE the fan is spinning just fine but its so annoying having to press F1 every time i turn on my pc
please help
The bios does not help me. the only option is "bypass F1 prompt on configuration changes" but that does not stop the F1 prompt for power supply fan not detected problem.
Windows 7 Pro x64i7 3770k 3.5ghz up to 3.9ghz turbo boost 4 co...32GB 4x8GB DDR3 1600mhz CL9 patriot viper gam...ZOTAC GTX 1650 low profile overclocked GPU
HP Elite 8300 compaq SFF
Windows 7 Pro x64
i7 3770k 3.5ghz up to 3.9ghz turbo boost 4 core 8 thread CPU
HP Elite 8300 compaq SFF OEM board
32GB 4x8GB DDR3 1600mhz CL9 patriot viper gaming ram
realtek integrated HD audio
23" acer gaming 144hz 1ms monitor
1920x1080 @120hz/144hz
ADATA 128GB SSD
ADAtA 256GB SSD
x1 Seagate 250GB 7200 RPM drive
x1 Seagate 500GB 7200 RPM drive
430w thermaltake smart
Stock + new thermal paste
REDRAGON mechanical blue switch
ZELOTES wired T-90 mouse
10MB/s (80mbps) download good internet
in-use/other
IE11 + firefox + Google Chrome randomly switches between
Info updated
power supply doesnt fit but still works with adapter its just sitting on the desk behind the computer wires going into the case where the old power supply was.
    7 X64i5 84002x8gb 3200mhz
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    pure power 11 400w cm
    Coolermaster
    cryorig m9i
    7x64g54008gb ddr4 2400
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
Too complicated and mine is HP 8300.
is there another way? Can I just run a jumper wire from CPU fan signal to the fan signal for the PSU?
Windows 7 Pro x64
ADATA 128GB SSD
ADAtA 256GB SSD
in-use/other
Info updated
You can try. If it doesn't work, you could try a mobo jumper as in the second video.
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
motherboard jumper wont work as its not a chassis fan thats the problem. its the "power supply" fan specifically so i dont think that will work.
I'll try the wire fan jumper thing later.
Windows 7 Pro x64
ADATA 128GB SSD
ADAtA 256GB SSD
in-use/other
Info updated
