HP Laptop running same speed on ethernet cable as Wireless
anthony george
1:53 PM
Redditch Worcestershire UK
Hi Everyone
I wonder if anyone can help me please.
Make HP g56 Laptop
ISP Virgin Media Cable 150 meg connection
Router Virgin Media Superhub
Norton Intternet Security
No other protection is turned on
I have two computers connected to the Hub
My wifes computer fujitsu 4 core runs at the true 150 meg speed with wired ethernet cable (Perfect)
My laptop however runs at half speed with wired ethernet connection. In fact it runs at the same speed as it does when connecting via wireless to the same superhub. about 75 megs.
I have posted an ipconfig image if this is any help.
Kindest Regards
Anthony George
windows 7 64 bit
windows 7 64 bit
Hi .... You have to remember it is up to 150mb ... You will not get this speed all the time ..
Have you just got Virgin Installed lately if so it takes some time to settle ...
Also does your Network Adapter support the top speed ? ...
As for wireless and Lan connections they can be the same speed with Virgin ... Though you should be getting more than 75mb at times ....
Virgin Media - Extremely fast broadband speeds
windows 7 home 64bitINTEL-CORE I716GB
W530-3630QM1
INTEL-CORE I7
16GB
750GB
