Intel Management Engine Interface shows ! on my control panel
EarlZ
7:45 AM
Can anyone help me sort this out, its the first time I've seen this and it looks annoying knowing that there is a form of error on my PC even though it does not affect my usage at all, I want to either get rid of this all together or find the necessary drivers for this to be fixed.
It also says Device cannot start under its device status, I have no clue what this thing is.
Windows 7 Ultimate X64 RTM
Q6600 @ 3.4Ghz
Abit IP35-E
8GB DDR2-800
GTX285 1GB
Creative X-Fi Extreme Music
Samsung T220
Samsung F1 Spinpoint 1TB
Silverstone Zues 750ZF
Lian Li PC-P80
Thermalright Ultra 120-Extreme
Windows 7 Home Premium 64 bit
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
You may want to right click on the device to uninstall it, then install it again using the downloaded file.
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Thanks!
Q6600 @ 3.4Ghz
Abit IP35-E
8GB DDR2-800
GTX285 1GB
Samsung T220
Lian Li PC-P80
Earlz, did it work? It's not a driver issue, the Intel will not work with Windows 7--I have the same issue.
HP Compaq 6910p
windows 7 pro 64 bit
Intel Centrino Duo-core 2.0 mhz.
HP
4 Gb's
Mobil Intel (R) 965 Chipset Family
37.26 ST94011A ATA Device Fixed hard disk media Fixed hard disk media CD/DVD ROM
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
