internet connection problem after system sleeps
Greg the bear
4:04 PM
Hello,
When my computer goes to sleep, when I start it back up, my internet shows it is connected. But nothing works. I get connection errors and also my email does not work. Will not download or send mail. If I restart, then everything is fine. I have a cable internet.
Any suggestions are greatly appreciated!
Greg the bear
Thanks for the idea. I tried it and below is a cut from the screen when I did the inconfig's. I tired to copy it here but it would not let me paste it in for some reason.
Anyway, it did not work. I still had to reboot my computer.
Everything was working good, until I loaded Yahoo Messanger. Is there something from it that could be causing my problem?
Thanks again
I believe that it has something to do with Yahoo Messenger 10. When I unloaded it, I quit having this problem. I seem to have another problem after doing so though. After doing so hyperlinks in my emails quit working. I found that if you load up Firefox, and unload it somehow it fixes it. I do not know about the unloading part, but it did start working after I loaded Firefox.
Hello,
I thought that I had this cured but it is back again. I have the power options setting on my computer as power saver. When my computer goes to hibernate, my internet connection is lost until I reboot. I at first thought that it was something wrong with Yahoo Messenger, but now I do not believe so. I'm thinking that it is something with the system going to sleep.
My system is a Dell XPS 710, I am running Win 7 64 bit. All else seems fine, just this problem.
All suggestions are appreciated. It is a big inconvenience having to reboot all of the time.
Thanks,
Greg
:confused:
Thanks Jonathan, It did have the box "Allow the computer to turn off the device " checked. I am trying it unchecked. Hope this works.
As for the drivers, as near as I can tell I am up to date on them. I did have a lot of trouble with the sound driver at first, but I was able to get one that would work with Win 7 and now all is well on the sound front!
Greg
:geek:
Hello, Back again on this one! Did not work! Any more suggestions?? :cry:
This has been a nagging problem that I have been having. Anybody have any suggestions?
Dell XPS 710
Windows 7 64
Intel 2.66 Quad
6G
NVideo
SB XFI
Dell Flat Screen and HP 2010I
2-500g 7200 SATA
XPS 710
Fans
wireless
Cable
Hello,
Greg the bear
Ho greg and welcome
try this next time you have the problem. type cmd in search> then
ipconfig /flushdns, then ipconfig /renew If that fixes the problem we know how to cure it
Hope this helps
Ken
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
Same Problem - eithernet connection only
I have the same problem with my wired connection. My wifi works fine but the wired connection disconnects after sleep mode.
I never had this problem before I upgraded to Win 7. Though I also updated to Yahoo Messenger 10 at the same time. Any ideas of how to fix this? Or is this something that I just have to accept and live with?
Dell XPS 710
Windows 7 64
Intel 2.66 Quad
6G
NVideo
SB XFI
2-500g 7200 SATA
XPS 710
Fans
wireless
Cable
Hey Greg - I have exactly the same problem on Windows 7 64bit (though I don't use it on a laptop). I have learned to live with it, but it has a really easy fix rather than a reboot every time.
Right click the little internet connection button in the corner, and click on 'Troubleshoot'. Fixes itself in <20 sec every time. Sorry I can't help with a permanent fix :/
J
i have this problem but with WI FI
it takes about 30 - 60sec then i can connect.
Mine keep changing to i have connection then i dont
Windows 7 Professional 64bit
Intel Core i5 - 2500K @ 3.30GHz
Gigabyte Z77-HD3
4GB DDR3
EVGA Nvidia GeForce GT 740 2GB DDR3
1T Samaung HD/ 1T toshiba external drive/ 1T western digital external drive/ 2T seagate external drive/ 250gb samaung SSD
Antec 430W
Microsoft Wireless Keyboard 800
Microsoft Wireless Mouse 1000
AVG
Internet Explorer
Dell XPS 420
6 gb
ATI Radeon 256MB HD3650
Intergrated 7.1 Channel Audio
Dell SP2009W 20"
640 GB Serial ATA Hard drive
Fan
Dell USB Keyboard
Dell Premium Optical USB
DSL 2.85
Windows has always had some bugs in conjunction with sleep-standby-hibernate I always turn off any and all power saving settings do to this.
I would recommend to turn off the power saving settings on the wired/wireless adapters themselves also create a custom power plan.
Something else is on laptops the OEM usually puts some software of it's own on for power control which will override the settings applied from Windows itself I would recommend uninstalling such software.
Windows 7 Ultimate 32 bit
AMD Athlon 64 X2 4200+ Overclocked to 3.0Ghz
Biostar TF560 A2+
2 Gigs of G.Skill DDR2 800
HIS ATI Radeon HD 2600 Pro With IceQ cooler
6.1 Channel Sound Blaster Live 24 Bit
Dual 20.5 " LG Flatrons W2052TO
1152x864
Dual 36 Gig 10,000 RPM Raptors
430 watt Seasonic 80%+ Dual 12v Rails 2x80mm fans
CHIEFMAX YA-5X
4-80mm case fans 1-140mm case fan freezer 64 Pro CPU cooler
Saitek Eclipse II
A4Tech wireless battery free optical scroll mouse
1.5 meg down 384 up
Logisys LED fan/light controller and dual 16" LED sticks mounted inside top of case all fans are LED all lighting is blue
DVD RW and CD RW both and Memory card reader
I'm with most of you in this thread?
I also have the same problem with sleep or hibernate with all of you above to a wired connection. The tray icon says "connected", but my browser (won't refresh site) & email client (won' get new emails or send) say "no"! I once was OK (Win 7 Pro) with an old (2Wire) modem/router (died in Dec. 2010) but failed with 2 brands of modem/router! :confused:
Dell/Optiplex 360
Windows 7 Pro at home, 2 Windows XP Pro where I volunteer
