Ipredator VPN connection problem (PLEASE HELP!)
Wanted
6:16 PM
Hey!
My Ipredator connection was working perfectly. I have different router now(be chose I live in another place right now), and when I try to connect Ipredator, it works about 20 seconds, and after that, it disconnects. I'm using Windows 7 x64. I usually get error report "Error 619. The port was disconnected" and couple of times I have got "Error 868. The name of the remote access server does not resolve"
I read somewhere, that with the error 619 is something to do with Windows 7 not supporting the router, be chose the router is based on Windows 2000. Is this true? (I'm not sure is the router based on Windows 2000, but it could be)
In Ipredator wep pages "Q & A" there is solution for error report 619, and there is a link for microsofts page, but the solution is for Windows 2000 or XP, and I'm using Windows 7 x64, so I dont think it works for me.
And of course I have read the instructions from Ipredator web page, how to connect Ipredator correctly, and I have done everything correctly, but it just wont work.
I have read many forums, but so far I haven't found any solution for my problem.
I have also sent an e-mail to Ipredator support, but it seems that they are not gonna answer...
Any help would be much appreciated!
Thanks!
Windows 7 Professional x64
AMD Phenom II 955BE Revision C3
Foxconn A7DA-S
4GB Kingston HyperX DDR2 1066mhz
ATI HD 4890 OC
Creative Sound Blaster X-FI Xtreme gamer
BenQ 21,5" 16:9 FullHD
Samsung 1TB
Seagate 1TB
Nexus NX-5000
Seriously? Does anyone have any kind of solution to my problem? :shock:
Thanks!
Foxconn A7DA-S
ATI HD 4890 OC
Samsung 1TB
Seagate 1TB
Nexus NX-5000
