Is the wifi connection speed thro router the same as wired ethernet
jraju
11:04 AM
Hi, I presume that my wifi access point ssid, from my router is given to me thro, bb connection .
Further that , i get now my wifi connection, thro , wireless nano adapter , the ethernet port not working.
My query:
I am having a bb speed of nearly 10 mbps download and .50kbps upload. never mind the upload.
Yesterday , i tried the speed test at ookla and my speed was reduced to 5mbps thro the wifi connection.This is probably because, smart phones were used along with the pc at that time.
I have disabled wifi on all other devices , except my pc and the speed test shows the original speed that I got it from using ethernet.
Is my presumption correct that,
the speed given by the bband connection thro ethernet /wifi are the same. I mean, the access point , ssid is thro wifi/ethernet the same?
and if you use some more devices , that this speed is getting distributed to number of devices accessing wifi
Microsoft Windows 7 Ultimate 64-bit 7601 Mult...Intel(R) Core(TM)2 Duo CPU E7200 @ 2.53GHz4.00 GBNVIDIA GeForce 210
custom build
To be filled by O.E.M. To be filled by O.E.M.
4.00 GB
NVIDIA GeForce 210
(1) NVIDIA High Definition Audio (2) Realtek High Definiti
ST3500312CS ATA Device
It depends on your router and your wireless card. If the router does 2 + 5 g then 5 g would be quicker but shorter range.
If your router only support n type it will be slower but if it and your wireless card both support AC and you connect to 5 g it would be 300mb+ but what is your internet package how much should you get?
win 8 32 bit
win 8 32 bit
Hi, Samuria, thanks for the reply. I usually get a fixed 12mbps download speed thro, my bb connection. Now that the Ethernet lan port is damaged, I have been using a wifi dongle to access my wifi to my pc.
My question is, is the speed thro Ethernet and wifi differs, in the sense, that wifi mode is different from wired Ethernet mode.Does it provide the speed thro, wifi and ethernet and speed is shared among the devices?
If suppose, I use only the pc, the speed would be 10 to 12 mb and if I use more than 3 devices, this speed is divided among the devices?
So be it wired or wireless , what your plan, the speed is distributed among the devices?
custom build
4.00 GB
NVIDIA GeForce 210
If you have 12 meg and 3 pc then each would only get 4 meg but it depends who got there first if the first pc download at 12 meg on its own it would criple anyone else loging on as it has priority
win 8 32 bit
win 8 32 bit
