Solved laptop replacement parts question
nfsworldpinoy
9:15 PM
my laptop's touchpad currently go crazy when im controlling it
what do you think is it faulty that i have to replace it or its just my system os, already tried restarting and system restore
what website can i buy this replacement parts and about how much range is this touchpad
my laptop is Acer Aspire 4750G
windows xp pro 32-bit
Windows 7 Ultimate 64
AMD FX - 8350 Oc
ASUS Crosshair V Formula-Z AMD 990FX
16GB Corsair Vengeance
HD 4870 1GB
Onboard.
Samsung Syncmaster 2032MW & ASUS p191
1 TB WD
320gb WD
650w OCZ PSU
Zalman Z11
Antec H20 920 , 6x Antec Quiet
Logitech RAZ71 Keyboard
Logitech RAZ71 Wireless Mouse
120mb Virgin
Malwarebytes
Try virus scan i know sounds silly.
Uninstall drivers and re install using these ones :
http://global-download.acer.com/GDF...ep3=ASPIRE 4750G&OS=ALL&LC=en&BC=ACER&SC=PA_7
Failing that Is it in warranty ? If it is a problem it may be cheaper buying a spares or repair laptop taking its parts as a last resort.
i bought it 10 months ago, it has a 1 year limited warranty for factory defect
but for personally damaged no warranty
we didnt even dropped it and it is very rare that we used the touchpad
Go for the warranty.
Yeah for the warranty if its still got 2 months left that is my point id wouldn't hesitate and get it fixed as it could be anything but better get sending off as times ticking till the day they actually get it in their hands.
Trust me it isnt worth solving yourself when its still in warranty hope that clears it up :)
AMD FX - 8350 Oc
HD 4870 1GB
Onboard.
1 TB WD
320gb WD
650w OCZ PSU
Zalman Z11
120mb Virgin
Malwarebytes
the next day when i removed my battery for a day then i put it back again
my touchpad is working, i dont know what happend but it works now
last few months when you press a key from the keyboard (long press) it freezes wwhen you let go of the key it does not freeze
man whats happening to my laptop
Dust/dirt interfering with contacts?
