LCD Water Damage, Need Help
devenprasad
4:42 PM
Canada
Hi There,
I have A Sony Vaio Laptop, but I split water into the lcd, i have dried it out but the lcd now has bright spots all over it (see attached images):cry: Is there anything that I would be able to do for example maby disassemble the lcd housing and clean the "optical Layer". Any Help Will Be graciously accepted and also Ps. I'm that kinda person that likes to void warranty to the extreme.
****If this is posted in the wrong "area" may a mod please put into the proper spot****
Edit: Sorry Forgot to attach the images
Thanks,
Deven Prasad
Sony Vaio VPCEB24FD
Intel Core i3 350M
Stock Foxxcon Board with American Megatrend BIOS
4GB Kingston DDR3 1033 Laptop Ram + 6GB Readyboost
ATI Mobile Graphics, Intel(R) HD Graphics (Battery Power)
Realtek Sound Driver
Generic PnP Monitor
1366 x 768
500 GB Western Digital Scorpio Blue SATA Drive
1TB Western Digital My Book With Cavalier Green Drive
SONY
Bright Blue Stock Case
Panasonic Heatsink Fan & No-Name Cooling Pad
Backlit "Chicklet" Ketboard
ALPS Touch Pad/Microsoft Wireless Mobile Mouse 3000
Shaw Cable 25mbps down, 2.5mbps upload
You, as an individual cannot repair the display, you're only hope is to replace it. A company that rebuilds LCD displays might be able to repair it, but it will require replacing some element of the panel assembly itself. Your hope would be to find a replacement LCD unit and change it yourself. A Guy
Windows 10 Home x64
ASUS P7P55D
LG 32MA68HY 32" IPS
ANTEC Three Hundred Illusion
85 + Mbps
Vivaldi
