Logitech Wireless Mouse Problem
OK, had a huge list of "Other Devices" and laboriously uninstalled all but the last. When I uninstalled it, I was prompted to re-boot to complete the process. Went to Explorer first to try and delete INFCACHE.1 but got blocked by security: "You need permission to perform this action. You require permission from Administrators to make changes to this file." I am an Administrator but was unable to delete the file. Allowed the re-boot to proceed and, voila, all the unknown devices are back!
http://www.sevenforums.com/tutorials/1911-take-ownership-shortcut.html?filter[2]=General%20Tips
Try it again :D
Something I threw together
Intel Core i7-2600K
Asus P8P67
16 GB G Skill F3-10666 CL9D-4GBRL
ATI Radeon HD 6870
ATI Radeon HDMI / Realtek ALC892
2 x 22" standard monitors / LG32LC56v TV to watch films
1920 x1080
2 x OCZ Vertex2 111.79GB
3 x Samsung103SJ
1 x Samsung103UJ
1 x WD3200BEVT
1 x Hitachi5K320-160
Thermaltake Toughpower Cable Management 750W
Antec 300
Noctua NH-U12P SE2 and 5 120mm Case fans
Microsoft Comfort Curve Keyboard 2000
Hama M3110 / Logitech M305
I have also used Fedora, Suse, Ubuntu Linux
And all other Windows from 95 to date except ME
I tried deleting the INFCACHE.1 file several times, even re-booting in between. I only have one user account on my machine - Me, Administrator. I'm assuming it's the file behind restoration of all the Unknown Devices.
I am not sure I follow were you successful in deleting it? did it work? And yes it is
In case its my bad; here is the full list;
  1. [FONT=&quot]Find and then right click on the file named INFCACHE.1.[/FONT]
  2. [FONT=&quot]Select Properties.[/FONT]
  3. [FONT=&quot]Click on the Security tab.[/FONT]
  4. [FONT=&quot]Click on Edit to edit the permissions of the file.[/FONT]
  5. [FONT=&quot]Click on Add to add User Groups.[/FONT]
  6. [FONT=&quot]Type Administrators in the User Groups field and click on OK.[/FONT]
  7. [FONT=&quot]Set Administrators to Full Control and click on OK.[/FONT]
  8. [FONT=&quot]Move or delete the file INFCACHE.1.[/FONT]
  9. [FONT=&quot]Reinstall a device to force Windows to rebuild the INFCACHE.1 file (DO NOT reinstall the same external hard drive that you were having issues detecting before. Please connect another USB device other than the one that Seven had an issue detecting).[/FONT]
You might have to do this several times
Intel Core i7-2600K
Asus P8P67
ATI Radeon HD 6870
1920 x1080
3 x Samsung103SJ
1 x Samsung103UJ
1 x WD3200BEVT
Antec 300
No, I wasn't able to delete it. But your steps to alter permissions will help I'm sure. Still a bit of a novice, I'm afraid, when it comes to dealing with Windows Security. e.g. when is an Administrator not an Administrator???
No worry I'm still trying to get this USB thing perfected :confused:
When windows decides otherwise :confused: I have tried to find an explanation as I don't know the answer but all I find are ways to change the permissions sorree
Intel Core i7-2600K
Asus P8P67
ATI Radeon HD 6870
1920 x1080
3 x Samsung103SJ
1 x Samsung103UJ
1 x WD3200BEVT
Antec 300
By default your user account will be a member of the administrators "GROUP" but you will still be restricted by Windows 7 UAC settings. One of the main differences between Windows 7 built in hidden Administrator account and your user account is the actual Administrator account doesn't have to contend with UAC. Its disabled when you log in with hidden admin account. You could temporarily turn UAC off while you try to sort this out. Then turn it back on to the default setting again when your done. It may make things easier.
Home Built
Windows 10 Education 64 bit
Thermaltake TR 620
Stock heatsink and fan
Logitech Wireless K350 Wave
80 Mbps Down 30 Mbps Up
Windows Defender
Internet Explorer 11
This sounds interesting. But, how do I access the "hidden admin account"? When I look at the User Accounts, all I see are myself and the "Guest" account (which is disabled).
Home Built
Thermaltake TR 620
Windows Defender
Logitech likes to "call home" (extra protocals). Anti-virus/and or firewall could possibly stop the outgoing call. backweb-8876480.exe
"backweb-8876480.exe" is installed with the software for Logitech products. It checks for software upgrades from Logitech.
It's present under Software => Logitech Desktop Manager, where it can be uninstalled
Windows 7 Ultimate 32bit SP1
INTEL/D975XBX2
ATI Radeon HD 2600 Pro
Samsung SyncMaster 914v
1280 x 1024
One is not connected
Rocketfish 700 W
G.Skill Gigabyte Chassis
Standard PS/2 Keyboard
Microsoft PS/2 Mouse
DSL
Avira Internet Security
IE 11
ATI HDMI Audio
Well, the good news is that my new Logitech mouse is now working. The bad news is that I had to re-install Windows.
I attempted to add Administrators to the Properties/Security setting for INFCACHE.1 but couldn't get beyond the spinning blue wheel, no matter how long I waited. I did manage to delete the file by changing my own access to "Full control". Then the fun began. Deleted all the "unknown devices" and re-booted only to lose my (PS/2) mouse control. Using Safe Mode and Restore, got control back and repeated cleanup steps. Lost track of all the variations of what went wrong over the course of the next hour or so but eventually ended up with no mouse and no KB control whatsoever, not even in Safe Mode. Nothing left to do at that point but insert the Windows install disk and start over from scratch.
Thanks to everyone for all your help and suggestions. It's been a true learning experience.
This is not supposed to happen :eek::confused: I tried this on my PC and it worked perfectly. Is it perhaps that you went out of order? or when deleting unknown devices strayed perhaps away from USB?
I am really sorry that you ended up reinstalling and at the same time glad that you got the problem sorted :D
Intel Core i7-2600K
Asus P8P67
ATI Radeon HD 6870
1920 x1080
3 x Samsung103SJ
1 x Samsung103UJ
1 x WD3200BEVT
Antec 300
I don't believe I went out of order. I went through the uninstall process for all the unknown devices - didn't touch the USB section at all. If any of the unknown devices were USB related, as I'm sure they were, I really had no way of knowing. The only difference I'm aware of, procedure-wise, is using a different means to delete INFCACHE.1.
But, thanks again for your persistence in trying to see me through this.
Ok thank you for this, I have now modified the method for deleting the infcache.1 so that hopefully no one else will have problems
Intel Core i7-2600K
Asus P8P67
ATI Radeon HD 6870
1920 x1080
3 x Samsung103SJ
1 x Samsung103UJ
1 x WD3200BEVT
Antec 300
